Adobe Photoshop Elements 4.0
For our Photoshop Elements test, we used a selection of 400 three megapixel photographs taken in a variety of surroundings using the batch file processing function in the Elements Editor. We performed all of the auto fixes, including Auto Levels, Auto Contrast, Auto Colour and Sharpen before resizing the image to 640x480 and saving as a high quality JPEG.
Sapphire CrossFireX 790FX
Gigabyte GA-MA790FX-DQ6
MSI K9A2 CF
Asus M2N32-SLI
Time in Seconds (lower is better)
Adobe Photoshop results don't actually fare too well on average. While the Gigabyte did churn out some mammoth performance in this test, the Sapphire performance is very similar to the nForce 590a and the AMD 790X boards that are generally much more affordable.
File Compression & Encryption:
Our file compression and decompression tests were split into two halves to cover a broad spectrum of performance. The first test we ran was to compress and encrypt the MPEG-2 source file from our video encoding test with the highest quality compression ratio. Secondly, we compressed and encrypted the folder of 400 photographs used in our Photoshop Elements test with the same compression settings.
MSI K9A2 CF
Asus M2N32-SLI
50
75
100
125
150
175
MSI K9A2 CF
Asus M2N32-SLI
The performance is again not bad – it’s better than the AMD 790X MSI results but not quite up to the seriously fast Gigabyte 790FX.
File Decompression & Decryption:
The two RAR archives created during the compression and encryption tests were then decompressed and decrypted.
MSI K9A2 CF
Asus M2N32-SLI
MSI K9A2 CF
Asus M2N32-SLI
Again, we see slightly faster and certainly consistent performance from the Sapphire.
Xvid Encoding:
We tested video encoding performance using VirtualDub-MPEG version 1.6.15 and a multithreaded version of the Xvid codec, along with the LAME MT MP3 encoder for encoding audio. We did a two-pass encode of a 15-minute 276MB digital TV recording with a target file size of 100MB.
MSI K9A2 CF
Asus M2N32-SLI
The Sapphire outperforms the other boards in Xvid encoding—even the Gigabyte 790FX board—although not by much, only a few seconds over the several minute test.
Posted by bubsterboo - Fri Feb 15 2008 09:07
http://www.ocxtreme.org/main/images/dfip35t2rpix/dfip35_1.jpg
OH, "
While previous Sapphire boards have been considerably, well... naff, the latest Pure CrossFireX 790FX has been backed by DFI - and just like other DFI boards, it's kitted to the teeth for enthusiasts!"
That's why
Posted by phuzz - Fri Feb 15 2008 10:25
Posted by Amon - Fri Feb 15 2008 10:46
Only a Prescott can do that.
