AMD Radeon HD 6950 1GB Review
Written by Harry Butler
February 11, 2011 | 11:48
Tags: #6950 #black-ops #cod #speed #temp #temperature #thermal
Companies: #amd
Power Consumption (Idle and Gaming)
Putting a realistic, repeatable load on a GPU to get a decent idea of its real world power consumption and thermal output has long been something with which we've experimented at bit-tech. We've found that synthetic benchmarks such as FurMark thrash the GPU constantly, which simply isn't reflective of how a GPU will be used when gaming.
It's such a hardcore test that any GPU under test is almost guaranteed to hit its thermal limit, the mark at which the card's firmware will kick in, speeding up the fan to keep the GPU within safe temperature limits. Conversely, simply leaving a game such as Crysis running at a certain point also isn't reflective of real world use. There's no guarantee that the GPU is being pushed as hard as other titles might push it, and the load will vary from play-through to play-through.
Eventually then, we've decided to use 3DMark06's Canyon Flight test as a real world representative, repeatable graphics test. It's a ferociously demanding test, pushing graphics cards to their limit, but also containing peaks and troughs in performance that match real world game play.
As the test is so demanding and GPU limited, we've set 3DMark to run the test at 1,280 x 1,024 with 0xAA and 16xAF (enabled in the driver), constantly looping the test for thirty minutes and recording the maximum power consumption and GPU Delta T (the difference between the temperature of the GPU and the ambient temperature in our labs).
Power Consumption (idle)
Windows 7 Desktop (Aero enabled) Idle Power Usage
  • AMD Radeon HD 6870 1GB
  • AMD Radeon HD 5770 1GB
  • Nvidia GeForce GTX 460 768MB
  • AMD Radeon HD 6850 1GB
  • AMD Radeon HD 5870 1GB
  • AMD Radeon HD 5850 1GB
  • Nvidia GeForce GTX 560 Ti 1GB
  • Nvidia Geforce GTX 460 1GB
  • AMD Radeon HD 6950 2GB
  • AMD Radeon HD 6970 2GB
  • AMD Radeon HD 6950 1GB
  • Nvidia GeForce GTX 570 1.3GB
  • Nvidia GeForce GTX 580 1.5GB
  • Nvidia GeForce GTX 470 1.2GB
  • AMD Radeon HD 5970 2GB
  • Nvidia GeForce GTX 480 1.5GB
  • 128
  • 129
  • 130
  • 131
  • 136
  • 136
  • 135
  • 137
  • 138
  • 141
  • 147
  • 150
  • 150
  • 160
  • 163
  • 164
50
75
100
125
150
175
Watts at socket, lower is better
Power Consumption (load)
3DMark06 Canyon Flight test, 1,280 x 1,024 0xAA 16xAF, Load Power Usage
  • 212
  • 229
  • 238
  • 245
  • 247
  • 256
  • 270
  • 270
  • 278
  • 285
  • 306
  • 330
  • 341
  • 347
  • 363
  • 376
200
300
400
Thermal Performance
Heat (idle)
Windows 7 Desktop (Aero Enabled)
  • 8
  • 10
  • 11
  • 14
  • 14
  • 15
  • 16
  • 18
  • 19
  • 19
  • 20
  • 20
  • 22
  • 23
  • 25
  • 26
10
15
20
25
Delta T in °C
Heat (peak)
3DMark06 Canyon Flight test, 1,280 x 1,024 0xAA 16xAF, Peak Temperature
  • 38
  • 44
  • 46
  • 46
  • 46
  • 46
  • 46
  • 46
  • 50
  • 50
  • 54
  • 54
  • 55
  • 56
  • 72
  • 72
20
30
40
50
60
70
80
Delta T in °C
For explanation of what these numbers mean, head to the Results Analysis page.
