Left 4 Dead 2
Developer: Valve Software
From our
Left 4 Dead 2 review:
'Not only does Left 4 Dead 2 provide a chance to test your skills against a whole host of new enemies and using a slew of new equipments, it also lets you play with the new modes and maps created by Valve – and the worst levels created by Valve are still twice as good as the best created by amateur map-makers.'
AMD A10-5800K (4.4GHz)
AMD A10-5800K (3.8GHz)
Intel NUC5i3RYK (Core i3-5010U)
Intel NUC D54250WYK (Core i5-4250U)
Intel NUC DC53427RKE (Core i5-3427U)
Intel NUC D33217CK (Core i3-3217U)
Frames per second, higher is better
Power Consumption
For the power consumption tests we aim to gauge real-world power draw. The power draw is measured via a power meter at the wall, so the numbers below represent the total system power draw from the mains, not the power consumption of a CPU itself. Measuring the power draw of any individual component in a PC is tricky to impossible to achieve. We used Prime95 to fully load the CPU.
Idle Power Consumption
For this test, we leave the PC doing nothing but displaying the Windows 7 desktop (with Aero enabled) for a few minutes and record the wattage drawn from the wall via a power meter.
Raspberry Pi (claimed power consumption)
Intel NUC Kit NUC5i3RYK (Core i3-5010U)
Intel NUC D33217CK
Intel Core i3-3220
Watts, lower is better
Load Power Consumption
To generate a realistic load power consumption figure we load the CPU using Prime95's small FFT test, which mimics 100 percent load across all logical and physical cores.
Intel NUC D33217CK
Intel Core i3-3220
20
30
40
50
60
70
80
