Radeon HD 4890 vs GeForce GTX 275
Written by bit-tech Staff
April 3, 2009 | 16:03
Tags: #275 #3 #4890 #article #compare #comparison #crysis #fallout #geforce #gtx #performance #radeon #result #review
Companies: #amd #ati #bit-tech #nvidia #test
Crysis
Publisher: Electronic Arts
Crysis is seen by many as the poster boy for DirectX 10 and it will make your system cry, quite literally – it’s a monster! It doesn’t come as much of a surprise then, that the graphics are something special – they’re above and beyond anything we’ve ever seen in a PC game.
We tested the game using the 64-bit executable under DirectX 10 mode with the 1.21 patch applied. We used a custom timedemo recorded from the Laws of Nature level which is more representative of gameplay than the built-in benchmark that renders things much faster than you're going to experience in game. We found that around 27-33 fps in our custom timedemo was sufficient enough to obtain a playable frame rate through the game. It's a little different to other games in that the low frame rates still appear to be quite smooth.
We set all of the in-game details to High and forced 8x anisotropic filtering in the driver menu as there is currently no support for it in game. We tested at 1,280 x 1,024, using 0x, 2x and 4x anti-aliasing, 1,680 x 1,050 using 0x and 4xAA, 1,920 x 1,200 using 0x and 2xAA and 2,560 x 1,600 with 0xAA and 2xAA. By extensively testing using anti-aliasing in very high resolutions in conjunction to Very High quality, we'll be pushing even the bleeding edge hardware on test to the limit.
Crysis
1,280 x 1,024 0xAA 16xAF, DirectX 10, High Quality
  • Nvidia GeForce GTX 285 1GB
  • Nvidia GeForce GTX 275 896MB (ForceWare 185.63)
  • Nvidia GeForce GTX 275 896MB (ForceWare 182.50)
  • ATI Radeon HD 4890 1GB
  • Nvidia GeForce GTX 260-216 896MB
  • ATI Radeon HD 4870 1GB
    • 55.0
    • 32.0
    • 53.5
    • 31.0
    • 52.1
    • 31.0
    • 44.5
    • 25.0
    • 41.0
    • 23.0
    • 38.2
    • 20.0
20
30
40
50
60
Frames Per Second
  • Average
  • Minimum
Crysis
1,280 x 1,024 4xAA 16xAF, DirectX 10, High Quality
    • 46.9
    • 28.0
    • 45.7
    • 27.0
    • 43.6
    • 26.0
    • 37.9
    • 19.0
    • 34.7
    • 20.0
    • 32.8
    • 17.0
20
30
40
50
Frames Per Second
  • Average
  • Minimum
Crysis
1,680 x 1,050 0xAA 16xAF, DirectX 10, High Quality
    • 45.1
    • 27.0
    • 44.2
    • 27.0
    • 42.8
    • 26.0
    • 35.6
    • 21.0
    • 33.7
    • 20.0
    • 31.6
    • 17.0
20
30
40
50
Frames Per Second
  • Average
  • Minimum
Crysis
1,680 x 1,050 4xAA 16xAF, DirectX 10, High Quality
    • 38.2
    • 24.0
    • 37.2
    • 23.0
    • 35.5
    • 22.0
    • 30.8
    • 17.0
    • 28.6
    • 17.0
    • 26.7
    • 14.0
20
30
40
Frames Per Second
  • Average
  • Minimum
Crysis
1,920 x 1,200 0xAA 16xAF, DirectX 10, High Quality
    • 37.0
    • 22.0
    • 36.1
    • 22.0
    • 34.8
    • 20.0
    • 32.5
    • 19.0
    • 28.0
    • 17.0
    • 27.1
    • 15.0
20
30
40
Frames Per Second
  • Average
  • Minimum
Crysis
1,920 x 1,200 2xAA 16xAF, DirectX 10, High Quality
    • 33.7
    • 20.0
    • 32.1
    • 19.0
    • 31.1
    • 19.0
    • 30.2
    • 17.0
    • 25.8
    • 15.0
    • 24.8
    • 14.0
10
15
20
25
30
35
Frames Per Second
  • Average
  • Minimum
Crysis
2,560 x 1,600 0xAA 16xAF, DirectX 10, High Quality
    • 22.5
    • 13.0
    • 21.9
    • 12.0
    • 21.3
    • 12.0
    • 19.4
    • 10.0
    • 16.9
    • 8.0
    • 16.5
    • 9.0
10
15
20
25
Frames Per Second
  • Average
  • Minimum
While fortune favours the brave, Crysis favours the GeForce GTX 275. The Radeon HD 4890 is consistently a few fps slower than the Nvidia card, which is a shame for ATI considering that its card costs the same, but is louder and produces considerably more heat. In the mid-range resolution and detail settings, the domination of the GTX 275 over the HD 4890 is clear. Take 1,680 x 1,050 with no AA for example, the GTX 275 sails through the game with a minimum of 27fps and an average of 44.3fps. Meanwhile, the HD 4890 is struggling to play the game smoothly at all, with a stuttery minimum of 21fps and a mediocre average of 35.6fps.
In fact, the GTX 275 is so good in Crysis, that it rivals the performance of the £300 or so GeForce GTX 285. That's £80 extra for around 1fps extra of performance? You'd be a fool to spend more than £200 unless you are running a really high resolution monitor. Only at the high resolutions does the slightly fatter memory interface of the GTX 285 give it a bit more of an edge over the GTX 275, but even then it's only by a couple more fps at most.
null
