Asus P5Q Series Motherboards!
BUILDING THE CASE
OK, here we go...
First stage - The case’s front panel.
Dark Crystal Lets get started...
Cut out parts of wood and acrylic and assemble them with bolts and screw nuts. The wood I used is pine of 22mm X 22mm section. The pine is a tender wood able to be cut and sandpapered very easily. The acrylic is 6mm thick which I recovered from the shielding of my father’s store shop-window.
Dark Crystal Lets get started... Dark Crystal Lets get started...
It was necessary to drill holes to pass the bolt shank very precisely in order to be able to easily pass through all the sections. I thus drilled the wood and acrylic at the same time so they all correspond perfectly.
Once all was in place, I put a screw nut at each side of the bolt stems and I tightened them as much as possible in order to make the nuts sink into the wood. I then cut and filed the excess length off the bolts so that the stems and nuts are not apparent any more. Then I repeated the same operation for the top of the case and I thought of making the rear case in the same way but the number of cutting for the exits (PSU/motherboard connections/ventilator…) did not allow it…
Then I continued the front face by cutting out the openings of the blowholes, LCD and slot-loading DVD. To do that I used a jigsaw. The great difficulty was not breaking acrylic parts because I wished to use them as grills for the front fans.
Here is the result after light sandpapering to the countour-line.
I did the same work for the LCD’s opening just like for the DVD drive slot opening.
Shopping
bit-tech Shopping
MSI 9800GTX Graphics Card
Stats: 0.060 seconds
