Temple of Nod
Written by Wil Harris
September 18, 2006 | 14:02
Tags: #atomic #command-and-conquer #edvuld #hotbox #led #temple-of-nod #westwood
Companies: #dremel
The final result
The case weighs in at about 13Kg with all hardware installed. My old case weights about 33Kg, so it’s a pretty big improvement. I was glad that I hadn't decided to install watercooling!
Here are the system specs, starting with the cooling:
  • 92mm Antec fan for intake
  • 92mm Papst fan for HD cooling
  • 92mm Papst fan on SLK947-U for CPU cooling
  • 92mm Zalman fan in tower for exhaust (using Zalmans resistor to reduce noise)
  • Zalman NB-47 (Blue one) on NB, and small black HS on SB.
  • Chieftec 340W PSU, stripped and modded
  • Lite-On 3540A DVD-Writer
  • Abit AN7
  • AMD 2500+ @ ~2.3GHz (less then optimal case temp prevents it from being overclocked much more)
  • Maxtor DiamondMax10 250GB SATA
  • HIS 9800PRO ICEQ
  • 1GB Corsair 3200XL
I used a total of 128LEDs, plus a few that got burnt along the way.
The final result
Internals:
Temple of Nod The final result Temple of Nod The final result
Externals:
Temple of Nod The final result Temple of Nod The final result Temple of Nod The final result Temple of Nod The final result
Lighting:
Temple of Nod The final result Temple of Nod The final result Temple of Nod The final result Temple of Nod The final result Temple of Nod The final result Temple of Nod The final result
