Team Fortress 2 Dispenser Mod
Written by Ton Khowdee
July 7, 2008 | 00:06
Tags: #dispenser #engineer #engineering #fortress #khowdee #orange #sentry #team #tf2 #titon #ton #worklog
Companies: #box #mod #valve
Blue Team Wins!
bit-tech Staff: So, now the Dispenser is built, painted, sanded and lookin'...well...it's hard to find the words without slipping into an over-excited string of swearwords and exclamations.
In the pictures below you can see for yourself just how gorgeously the Dispenser is when it's fully unveiled and put together. Bear in mind that this is only the first part of this two-part mod too and the second part, detailing the design and construction of the Team Fortress 2 Sentry PC, will be up in just a few days - only on bit-tech!
In the meantime, take a gander at all the pictures below and be sure to click them for enlarged versions which really show off TiTON's stunning craftsmanship!
Team Fortress 2 Dispenser Mod Team Fortress 2 Dispenser Mod - Gallery Team Fortress 2 Dispenser Mod Team Fortress 2 Dispenser Mod - Gallery
If you've got any mods of your own which you want to show off, or if you're just interested in checking out the other mods that we've hosted in the past, then you can check out both the Modding Section, or the bit-tech Project Logs forums where modders from all over the world show off their best mods and designs.
If on the other hand you're a modding noob and are more interested in learning the basics then we've got a number of small mods that may be suitable - everything from how to make your own retro-styled USB sticks to guides that introduce you to the basics of watercooling, if that's more your speed.
If on the other hand then you want to pass on your congratulations to TiTON, or if you think you've spotted a detail he's missed (not bloody likely!) then you can get in touch with him via this discussion thread.
