Shuttle introduces Mini-PC Media-Centre for Blu-ray and HD DVD
A must-have for owners of high-resolution flat-screen televisions
Shuttle Inc., the market leader in the Mini-PC market segment and the manufacturer of Multi-Form-Factor solutions, launches its first AMD-based HD-compatible Mini-PC Complete System. The ready-to-connect aluminium solution can play high-resolution films from both Blu-ray and HD DVD media. A single HDMI cable transfers top quality image and sound to modern flat-screen televisions for play back, thereby avoiding any expensive installation costs.
"The LG GGC-H20L Combo drive is suitable for both HD formats and AMD's Athlon 64 X2 6000+ processor and in conjunction with the 2GB DDR2-800 memory delivers the required performance for fluid playback", explained Tom Seiffert, Head of Marketing & PR at Shuttle Computer Handels GmbH.
A fully-fledged Media Centre not only stands out due to its fluid playback of cinema films and its ability to run all types of round disks, it also offers TV-reception with expanded options. Whether it is conveniently managing recordings with the remote control or using the Time-Shifting function to ensure you never miss a second of the ongoing program - home cinema is fun. You can use the LG GGC-H20L Combo drive to burn TV recordings, digital photos or music saved on the Shuttle XPC G5 6801M onto DVD.
As a normal operating system runs behind the user-friendly Media-Centre Windows Vista Home Premium interface, all commercially available programs can be installed and used. Many PC-games can also be enjoyed on the home television. The configuration of the Mini-PCs is rounded off with 8-channel audio, Gigabit-LAN, FireWire, six USB-Ports and eSATA-Ports covering all the options you may wish for.
The configuration of the Mini-PC is rounded off with 8-channel audio, Gigabit-LAN, FireWire, six USB-Ports and eSATA-Ports covering all the options you may wish for.
Technical specifications:
* Mini-PC Complete System is based on: Shuttle XPC Barebone SN68SG2 with the PF27 front panel from the "Shuttle XPC Accessories" program.
* Processor: AMD Athlon X2 6000+
* Memory: 2x 1GB DDR2-800
* Hard disk: 500GB, Serial-ATAII
* Graphics Card: ATI HD3450, 256 MB
* Wireless Communication: Wireless LAN
* Optical Drive: LG GGC-H20L Blu-ray/HD DVD Combo
* TV Tuner: DVB-T/Analog Hybrid
* Other Drives: 25-in-1 Card-Reader
* Other configurations: Remote control and multi-functional front display
* Operating System: Windows Vista Home Premium
* Dimensions: 310(D) x 200(W) x 185(H) mm
The configuration described here can be changed in the Shuttle Systems Configurator to suit your own preferences.
Shuttle Systems Configurator:
http://sys.eu.shuttle.com/home.jsf?showProduct=G5%206801M%20Vista
For servicing the purchaser of the Complete System can make use of the 24 month Pick-up-and-Return-Service and a Europe-wide free telephone hotline.
The Shuttle XPC G5 6801M is available immediately in specialist retailers.
Shuttle's recommended price is EUR 1,234 (w/o VAT).
Press release and image resources
http://eu.shuttle.com/en/DesktopDefault.aspx/tabid-53/140_read-14727/
