This press release is written by a third party and the content does not reflect the opinion of bit-tech's editorial team
Thermaltake PW 850i Opens the New Era of Internal Liquid Cooling System
Internal DIY Liquid cooling system has always been the top choice of the worldwide gamers. To fulfill the heavy demands of these heavy players, Thermaltake is launching a brand new series of DIY liquid cooling system- ProWater series. And the first model to be introduced is the new PW850i that incorporated the latest production mechanism and technology of the internal liquid cooling world.
The P500 Pump used in PW850i has high water volume of 500L per hour to support the heavy operations of liquid cooling systems; the hard-wearing ceramic bearing further increases the life span of the pump, you will not need to worry about any pump power problems even with extended VGA or memory liquid cooling components in the future. The professional designed inlet and outlet will eliminates possibilities of air blockage. PW850i also adopts the automotive style radiator with the Thermaltake exclusive dimple dimpled tubes, DDT technology rather than the traditional ones and the adjustable fan (1300~2400 RPM); CPU heats will be transmitted efficiently in the coordinated system environment.
All copper Waterblock does not only have perfect heat conductivity, it is also very suitable for high temperature welding. The coolant channels between the cooling fins in the copper base take away the heat efficiently and effectively. The reliable brazing copper process adopted at Thermaltake ensures a leak-free internal liquid cooling system even after long hours of operation.
Other than the superb components, PW850i also incorporated many user-friendly designs; the additional Flow meter provides a clear and stylish system operation index. And the transparent UV 3/8 inch tubes with iStripe maintain smooth water flow even with sharp bending radii and 500L of water volume per hour. Moreover, in order to avoid possible low coolant level dangers, level marks have been added on the new huge transparent tank in PW850i, making coolant maintenance and monitoring easier than ever before. With easy coolant adding design, PW850i has been carefully produced to provide a safe, leak-free and easy building but still stylish liquid cooling system of your own.
Thermaltake all new PW850i Internal DIY Liquid Cooling System will satisfy all cooling demands in any system environments; It will definitely be your best choice for a quiet and efficient liquid cooling system!
http://www.thermaltake.com/product/Liguid/DIY/cl-w0175/cl-w0175.asp
