With the latest power supply technology, the SilverStone Nightjar NJ450 is capable of continuous power output at 450W with a peak up to 500W. Built and engineered from a 600W platform, the NJ450’s fan-less thermal solution is also able to satisfy enthusiasts that require stable output and no noise operation. Its server-level components help to ensure high reliability while its sophisticated architecture maintains 80% efficiency for nearly all loading levels. Coupled with this excellent power supply are features that include single PCI-E 8pin connector, dual PCI-E 6pin connectors to support high-end graphics cards, and finely crafted extruded aluminum construction. The NJ450 is truly an aesthetic innovation at its best.
Special features:
Fan-less thermal solution, 0 dBA acoustics
Efficiency greater than 80%
450W continuous power output with 500W peak
Single PCI-E 8pin and dual PCI-E 6pin support High-end GPU
All aluminum construction
Server-level components
Status indicator LEDs
Support ATX 12V 2.3 & EPS 12V
Active PFC
