Extended from the Red Dot Award 2008 honored design of V1 cooler; Thermaltake, the leading brand of global CPU cooling industry, announces the new release of the silver shining V1 AX, a ultra-high performance next generation CPU cooler with friendly price tag but supporting most mainstream processors (Intel Socket LGA775 and AMD Socket AM2+ / AM2 / K8).
On the cooling front, V1 AX utilizes the newly developed 4 Channel – Dual-VTM Architecture Heatpipe Cooling, where V shaped aluminum fins are seamlessly attached onto 963mm heatpipes to accelerate heat dissipation. Mirror finished copper base further increases the heat absorption rate to effectively remove heat from processors. Over-sized 110mm fan with all-range variable speed controller allows flexible adjustments on the fan speed according to various system requirements. Open-frame design on the fan further reduces air pulsating noise of most cooler fans, and thus reaching a nearly silent operation condition.
Side flow design utilizes system air and allows the cool system air to pass through the cooler and achieve more effective cooling than ever before. The unique architecture of V1 AX provides multi-directional air intake that absorbs more cool air to achieve better thermal performance.
Thermaltake New V1 AX CPU Cooler with the streamlined body designed not only increases airflow through the aluminum fins but also forms a distinctive look that will surely to catch the attention of any PC enthusiasts and overclockers.
www.thermaltake.com/product/Cooler/Retail/Cl-P0508/features.html
About Thermaltake
Thermaltake Incorporation, based in Taipei, Taiwan is the global leader Thermal Solution and Thermal Management for PC & Industrial Market. Its engineering staffs master in Airflow Analysis, Material Conductivity and Heat Dissipation Efficiency. Thermaltake offers a wide range of products and services, providing effective and cost-conscious cooling devices. The Company has more than 1,000 employees worldwide supporting customers from its headquarters in Taipei, Taiwan, as well as from offices in China, Europe and United States Continent.
