Don’t leave your presentations in the dark-ages. BenQ launches their ultra bright “lights on” DLP projector range.
Hemel Hempstead, London, 30th July – BenQ presents two exciting new digital projectors; the SP920 and the SP870. Both XGA projectors (1,024 x 768 resolution) deliver an ultra-high brightness level, with the SP920 boasting an impressive 6,000 ANSI lumens, and the SP870 5,000 ANSI Lumens. Users will no longer have to turn off lights when showing presentations, as the BenQ SP920 and SP870 are suitable for high-ambient-light environments ranging from meeting rooms to auditoriums.
These two models are at the top end of BenQ’s compelling data & home digital projector range of over 20 models, so BenQ are now sure to have a model for everyone’s projection needs.
In addition to featuring a super brightness level, the SP920 and SP870 also packs in the punches with a full suite of features – including 2,000:1 sharp contrast ratio, BrilliantColor™, Presentation Timer, Quick Auto Source (the industry’s fastest source detection), 30-second Quick Cooling, Lamp Care, Wall Color Correction, 3D colour management, and Blackboard Mode allowing users to focus on a perfect presentation instead of fumbling with setup. With all these features they truly are the perfect presentation partner.
The DLP® BrilliantColor™ chipset, enables the SP920 and SP870 to perform multicolour processing for vibrant colours on the screen, ensuring higher brightness and superior contrast for deeper blacks and brighter whites. The Independent Colour Management feature offers independent adjustments to red, green, blue, cyan, magenta and yellow to fine-tune the hue and saturation.
The SP920 also comes equipped with a dual lamp offering three sets of lamp mode; allowing for operation in large, mid-large or normal-sized rooms. For large rooms and auditoriums 6,000 ANSI lumens with dual lamp (Normal Mode) are suitable to deliver a bright and clear image. The dual lamp (Eco Mode) delivers 4,800 ANSI lumens which manage mid-large presentation situations. In normal-sized environments 3,000 ANSI lumens with a single lamp (Normal Mode) are sufficient. In this case, the second lamp will be on standby which saves electricity and extends the lamp lifetime.
Engineered to operate in fully lit environments, the SP920 arrives with UNISHAPE technology which enables the projector to render brighter images with richer colour depth at higher contrast. With UNISHAPE, the SP920 is able to counteract loss of image brightness by varying the intensity of the projector lamp in synchronisation with the colour wheel, resulting in a 40% increase in image brightness and boosting specific colours in different setting modes.
The BenQ SP920 and SP870 are available from early August 2008. The recommended retail price for the SP920 is £2,999 ex. VAT and for the SP870 is £1,299 ex. VAT
For further information please visit
www.benq.co.uk
SP870 specifications:
Native Resolution XGA (1024 x 768)
Resolution Supported VGA (640 x 350) to SXGA (1280 x 1024)
Brightness 5000 ANSI lumens
Contrast Ratio 2000:1
Image Size 40” to 300”
Throw Ratio 60”@2M (60”@6.6 feet)
Zoom Ratio Manual Zoom, 1.15:1
Lens F=2.4~2.7 , f=38.87~46.63mm
Light Source 360W, 2000/3000 hours (Normal/Economic mode)
Operational Noise 36/33dB (Normal/Economic mode)
Displayable Colours Full 16.7 million color palette
Aspect Ratio 4:3 Native, 16:9 Selectable
Horizontal Frequency 31-93 kHz
Vertical Scan Rate 48-85 Hz
Input Sources
PC
Analog RGB: D-sub 15 pin x 1
A/V
Component Video: RCA x 3
S-Video: Mini Din 4 pin x 1
Composite Video: RCA x 1
DVI-D(HDCP support) x 1
Audio
Stereo mini jack x 1
Output Terminals PC: 12V Trigger D-sub (15 pin) X 1
Audio 2 Watt Speaker x 2
Video Compatibility NTSC/PAL/SECAM
Dimensions (HxWxD) 375 x 115 x 277 mm
Net Weight 4.9kg
Power Supply 100 to 240 VAC, 50 to 60 Hz
Power Consumption (Max) 510W
OSD(On-ScreenDisplay) languages
Czech/Dutch/English/French/German/Italian/Japanese/Korean/Polish/
Portuguese/Russian/Simplified Chinese/Spanish/Swedish/Thai/
Traditional Chinese/Turkish (17 Languages)
Functions
3D Color Management, Quick Auto Search, Time Controller, Presentation Timer, Power On/Off Ring Tone, Panel Key Lock, Resolution Reminder, 11 sets of Picture Mode, "Q?" Hot Key for FAQ, Freeze, Lamp Care, Wall Color Correction, BrilliantColor, Blank (ECO mode), Quick Cooling, Auto Off, Security Password, My Screen, HDCP compatible, HDTV compatible, 12V trigger, High altitude mode
SP920 Specifications:
Native Resolution XGA (1,024 x 768 )
Projection System DLP®
Brightness 6,000 ANSI lumens (2 lamps/Normal mode); 4,800 ANSI lumens (2 lamps/Eco mode), 3,000 ANSI lumens (single lamp/Normal mode)
Lamp 280 W/230 W (2 lamps), 2,000/3,000 hours (Normal/Economic mode)
Contrast Ratio (FOFO) 2000 : 1
Weight 24 lb (< 11 kg)
Noise Level 37/34 dB (Normal/Economic mode)
Resolution Support 640 x 480 to 1,600 x 1,200
Dimension (W x H x D) 443 x 167 x 355 mm
Image Size 31 to 300 in
Projection Ratio 60 in @ 6.6 ft (60 in @ 2 m)
Throw Ratio 1.64 to 1.88 : 1
Throw Distance Min.: 1.2 m; max: 10 m
Keystone Adjustment Vertical ±25 degrees
Zoom Ratio Manual zoom, 1.15 : 1
Colour Full 16.7 million colour palette
Aspect Ratio 4 : 3/16 : 9 screen selectable
Horizontal Frequency 31–82 kHz
Vertical Scan Rate 48–85 Hz
Input Terminals
PC analog RGB: D-sub 15 pin x 1
HDMI (ver. 1.3)
DVI-D (HDCP support): x 1
Component: RCA x 3
S-Video: mini DIN 4 pin x 1
Composite : RCA x 1
PC audio: stereo mini jack x 1
Output Terminals
12 V trigger
Computer Compatibility VGA (640 x 480) to UXGA (1,600 x 1,200)
Speakers 5-watt speaker x 2
Control Terminals USB connector: USB x 1, type mini B
Serial connector: RS232 8 pin mini DIN
Wire control: mini jack x 1
Auto Switching Power Supply 100 to 240 V AC, 50 to 60 Hz
Power Consumption Max. 805 W
Functions
Dual lamp (3 sets of lamp mode), 3-D Colour Management, Quick Auto Search, Sleep Timer, Presentation Timer, Power On/Off Ringtone, Panel Key Lock, Resolution Reminder, 11 sets of Picture Mode, "Q?" Hot Key for FAQ, Freeze, Lamp Care, Wall Colour Correction, BrilliantColor™, UNISHAPE, Blank (ECO mode), Quick Cooling, Auto Off, Security Password, My Screen, HDMI (ver. 1.3), HDCP-compatible, HDTV-compatible, 12 V trigger, High altitude mode
About BenQ Corporation
BenQ Corporation, a leading provider of networked digital lifestyle devices, is a multi-faceted company with strengths in mobile communications, visual display and network and digital convergence technologies. BenQ offers unrivalled breadth and depth of products and integrated technologies across platforms through the brand promise of “Bring Enjoyment and Quality to Life,” including digital projector, LCD monitors, LCD TVs, digital cameras, mobile phones, laptop PCs, storage devices, media and human interface devices such as mice and keyboards.. 2006 revenues of BenQ Corporation exceeded US$6.2 billion dollars.*1
About BenQ Group
The BenQ Group is currently comprised of 12 companies that operate independently while sharing resources and leveraging synergies among them. The BenQ Group companies include BenQ Corporation, AU Optronics Corporation (world’s top 3 manufacturer of large-size TFT-LCD panels), Qisda Corporation, Darfon Electronics Corporation, Daxon Technology Inc., Daxin Materials Corp., BenQ Guru Software Co., BenQ Hospital, Darwin Precisions, Ltd, Raydium Semiconductor Corporation, Cando Corporation and Wellypower Co., Ltd. 2006 revenues for BenQ Group exceeded US$16.5 billion dollars.
For more information, please visit our website at BenQ.co.uk
*1 consolidated revenue of branded and manufacturing business.
DLP™ & BrilliantColour™ are registered trade marks of Texas Instruments.
