HydroGen, now with more graphics and less motherboard
This is one for you watercoolers - MSI has launched its latest GeForce GTX 280 with a funky HydroGen waterblock. The "N200 series" features a 700MHz core clock that MSI claims is one of the highest core clocks out there at a 17 percent improvement over stock.
The HydroGen block also sports a 10°C drop compared to the stock cooler but appears not to include the memory with its water coverage. Instead it relies on just a simple copper plate to conduct the heat to the water channels over the large core - much like the Danger Den block used on BFG Tech's GeForce GTX 280 H2OC.
MSI also states that it fits in a single slot now, but the PCI plate is clearly dual slot, unlike the BFG card, whose backplate has been changed to a single slot one. You lose the LED, but honestly - if you're competent enough to use watercooling you don't need to be told how to plug a graphics card in.
In the past, MSI's HydroGen was simply a concept as part of a potential watercooled X38 motherboard - we were first on the scene last year with that one. However, MSI couldn't make it into mass production back then even despite the superior design to other market leaders - this time though, around it seems to have made the big time.
We will be putting both up against each other in a head-to-head soon! Fancy grabbing yourself a watercooled GeForce GTX 280 without killing your warranty? Let us know your thoughts in the forums.
MSI watercools its GTX 280 with HydroGen MSI Watercools its GTX 280 with HydroGen
Quote Teknokid 3rd September 2008, 16:36
That is one sexy card!
Quote _DTM2000_ 3rd September 2008, 16:41
I slightly prefer the look of that to the BFG version. It looks more slick and expensive. I bet this doesn't have a lifetime warranty like the BFG though, which is a shame.
Quote GregTheRotter 3rd September 2008, 16:43
nothing like knowing that card has a warranty that will last longer than the time you'll actually use the product i.e 5 years-ish?
Personally I'd take EVGA's step-up program over BFG's lifetime warranty.
Quote keir 3rd September 2008, 16:45
Hmm I don't like it. I preffer the BFG block.
Quote M4RTIN 3rd September 2008, 16:47
doesnt look like they finished it
Quote Teknokid 3rd September 2008, 17:14
heatkiller blocks look the nuts IMO, there sli connectors are also pretty cool, lets hope MSI includes them :D
Quote devdevil85 3rd September 2008, 17:37
vetty nize
Quote Sim0n 3rd September 2008, 18:10
Doesnt look like its SLi compatible, which.. if your spending that kinda money on a card, you would hope was designed in..
BFG is sli compatible :(
Quote Teknokid 3rd September 2008, 18:24
it is :)
http://www.watercool.de/online-shop/
Quote Sim0n 3rd September 2008, 18:34
The *BLOCK* is available to support sli etc.. but will MSI give you that option ?
Quote Teknokid 3rd September 2008, 18:43
its the same block, just with an sli bridge block?
Quote Tim S 3rd September 2008, 19:27
yep, looks like the SLI bridge block is available separately, although my German isn't that sharp. :)
Quote docodine 3rd September 2008, 22:57
Agreed, but the sexiness crown stays with the Asus N7800GT DUAL.
Quote samkiller42 4th September 2008, 00:38
Nice looking card, think i will go with the BFG though, it's £360 price tag from scan is reasonable enough to me.
Sam
Stats: 0.259 seconds
