Great news for Liquid Cooling System enthusiasts! New liquid cooling system upgrade from Thermaltake --- WB200 brazing copper waterblock for North Bridge!
North Bridge thermal issue is often neglected in pc cooling field; but all true pc enthusiasts know it not only important, but one of the vital elements to the computer performance. Thermaltake new WB200 is a perfect solution to north bridge cooling in liquid cooling application. WB200 is purely copper-made for efficient and speedy heat dissipation in the first place; adding up the flawless contact surface with the chipset and the well-know brazing technology advance from Thermaltake, WB200 should definitely guarantee impressive performance without worrying about leakage problems.
Moreover, the Rotational Hose Connector used for connecting the tube and WB200 had made installation extremely easy! Thermaltake continuously brings innovative ideas with premium quality products to PC DIY world; even with a small upgrading waterblock, you can easily discover the great efforts put in user care and product design. If you are one PC DIY or liquid cooling system expert, you should definitely check out the New Pure Copper North Bridge Waterblock from Thermaltake: WB200
www.thermaltake.com/product/Liguid/Upgrade/cl-w0182/cl-w0182.asp
About Thermaltake
Thermaltake Incorporation, based in Taipei, Taiwan is the global leader Thermal Solution and Thermal Management for PC & Industrial Market. Its engineering staffs master in Airflow Analysis, Material Conductivity and Heat Dissipation Efficiency. Thermaltake offers a wide range of products and services, providing effective and cost-conscious cooling devices. The Company has more than 1,000 employees worldwide supporting customers from its headquarters in Taipei, Taiwan, as well as from offices in China, Europe and United States Continent.
Stats: 0.026 seconds
