Scythe Co., Ltd (Tokyo, Japan) announces “Kama Reader 2”, the upgraded version of its 3.5inch Card Reader Device, “Kama Reader” (former name), compatible for both internal and external usage purposes. Direct insertion of microSD & Memory Stick Micro is the new feature for this upgraded version. Precise fit into the 3.5inch bay of your PC case or use this as external card reader device with easy-plug-in USB connection for notebook PC users. Easy data transfer of your memorable photos from trips, music, or any data stored in your media card into your PC. Simple plug-in via USB as external card reader for quick and easy usage, or build-in usage to complete your PC to use as internal devices. Compatibility is r eady for most of the medias available in the market!
Modelname:
Kama Reader 2
Model #:
SCKMRD-2000-WH (white)
SCKMRD-2000-BK (black)
Manufacturer:
Scythe Co., Ltd.
Dimensions:
101 x 122 x 25.5 mm / 3.98 x 4.80 x 1.00 in (WxDxH)
Compatibility of CardReader:
Compact Flash TYPE1/TYPE2/TYPE2-HDD | Smart Media/Memory Stick, Memory Stick ROM/PRO/Duo/PRO Duo/Micro(M2) (nur 3,3V!), SD Memory Card (CLASS2/CLASS4/CLASS6) | SDHC Memory Card (CLASS2/CLASS4/CLASS6) | miniSD Card, miniSDHC Car (CLASS2/CLASS4/CLASS6) | microSD Card (TF=Trans Flash), microSDHC Card (CLASS2/CLASS4/CLASS6) | MultiMediaCard =「MMC」,(MMC4.0), RS MMC (4.0), MMC micro | Microdrive, xD Picture Card, xD Picture Card Type M | xD Picture Card Type H
Attention: This item is not compatible to read the copy-right protected data.
Supported OS:
Windows XP/2000/Vista + Mac OS X
Connection:
Card Reader: USB 2.0 or Internal USB Header-Pin
Mounting:
3.5inch Internal or External Connection via USB
MSRP:
$19.50 (USD)
10,50 (EURO) excl. VAT
For further information & images regarding this product, please visit our website at:
www.scythe-eu.com/en/products/pc-accessory/kama-reader-2.html#c2432
