AMD has this morning introduced the Radeon HD 4550 and Radeon HD 4350 graphics cards at the bottom of its Radeon HD 4000 series line up.
They're targeted more at the HD multimedia enthusiasts than they are at gamers, but AMD says that they should deliver good gaming experiences at their respective price points of $59 and $39 USD respectively.
Both cards are based on AMD's RV710 graphics chip, which is a cost-cut version of the excellent RV770 architecture.
RV710 features 80 stream processors, eight texture units, four render back ends (ROPs) and a 64-bit memory bus width. The chip is built on one of TSMC's 55nm processes and AMD says it packs 242 million transistors in.
Interestingly, both the 4550 and 4350 have the same 600MHz core clock – the only differentiation is the memory type, size and clock speed. The Radeon HD 4550 features DDR3 memory clocked at 1,600MHz (effective) in either 256MB or 512MB quantities, while the 4350 features 256MB of DDR2 memory clocked at 1,000MHz (effective).
Like its bigger brothers, RV710 supports eight-channel audio via HDMI and also includes the second generation Unified Video Decoder hardware, enabling smooth HD media playback. This means that Avivo HD technology also makes an appearance and will enable functions like noise reduction, colour enhancement and adaptive motion de-interlacing.
Expect boards to be available from the usual suspects over the coming weeks and days.
While they're right at the bottom end of the spectrum and unlikely to attract massive attention from a typical bit-tech reader, would you like to see us review these new entry-level cards from AMD? Let us know your thoughts in the forums.
Quote steveo_mcg 30th September 2008, 16:12
I think a quick less in-depth review might be of benefit. It would be good to know if they coped with video off loading and how noisy they were but not whether they could play crysis at 640x480 at 10 fps.
Quote TreeDude 30th September 2008, 16:19
If these can take enough of the decoding off the processor I might be able to buy this and a Blu-Ray drive for a HTPC. I have a P4, mobo, RAM, and PSU.
Quote teamtd11 30th September 2008, 16:19
I think the most i would put though one of these would be a source game. though i think i will get one for hd playback and keep my x1900 for gameing.
one thing though, if this is for hellping hd playback will the faster memory make any differance?
Quote badders 30th September 2008, 16:20
+1
I'd like to see the drop-off from the 4650 to these too, especially in some light gaming (HL2 for instance)
Quote Er-El 30th September 2008, 16:32
I'd appreciate any review of these as I'm interested in putting one in the next PC I'm assembling for the family, which will have a BD-ROM drive. So I'd like to see a test of how it performs with 1080p playback.
Quote Bauul 30th September 2008, 18:45
Yes please. Don't worry about doing anything indepth, we're just interested in whether they're good, bad, or somewhere in the middle. For a cheap multi-media PC or something for those a super tight budget they may be good purchases.
Quote cdawzrd 30th September 2008, 20:10
3870 vs 4650 vs these on Steam engine (TF2 maybe to be a little more demanding than HL2) and maybe something like COD4? Make the rest of the tests about video/audio, though :D
Quote Tile 30th September 2008, 20:11
Deleted
Quote fathazza 30th September 2008, 20:38
Originally Posted by Tile
A full roundup of low-end video cards from Ati and Nvidia would be great.
2nd'ed plus comparison to the main integrated graphics mobo chipsets (780g /8200 or whatever is just round the corner)
with the 8 channel audio, does that mean lpcm only or is powerdvd/windvd etc able to send bitstream these days?
Quote HourBeforeDawn 30th September 2008, 21:10
ah this is what I was looking for in my HTPC, it looks like its low power too and a passive sink will most likely work well for it so yay cant wait.
Quote Er-El 30th September 2008, 22:16
I believe if you've got the right software (the latest version of either PowerDVD/WinDVD) it can pass any lossless audio such as Dolby True and DTS HD, as well uncompressed LPCM.
Quote 1ad7 1st October 2008, 00:41
REVIEW THEESE BIOTCHES lol maybe play mount and blade with it? lol And of course blu ray play back and noise thats about it, maybe a subjective audio review via hdmi?
Quote dixie_flatline 1st October 2008, 01:53
I wonder if you could run them in Crossfire...?
I'll take 9 thanks.
Quote Invader Phlegm 2nd October 2008, 19:13
I read at Engadget, that CrossfireX is supported "in case you want to pair two of them up".
All in all, not a bad list of features for such an inexpensive, little card. I was actually in the process of building a couple of HTPCs for the homestead, and I'd be interested in seeing what the gains of using a couple of these in Crossfire vs. using them standalone, would be.
Also like to see how well they handle video transcoding. Now that they have a new digital camcorder, the family has gotten into home video in a big way. Of course the camera does not film in divx or mkv, and the files have to be converted. If I can offload that task to the HTPCs and off my main desktop, and get reasonable results, it would be a lifesaver . . . not to mention, I can finally get my computer back from the missus.
