_Get your FREE 2Gig USB Flash Super Stick Drive
GIGABYTE UK is offering a FREE 2Gig USB Flash Super Stick Drive to any end-user who buy's the GIGABYTE GA-EP45-DS4 motherboard.
The best thing of all is that we, GIGABYTE, will send the 2Gig USB Flash Super Stick Drive directly to the end-user, with no extra cost to you.
In fact, you don't even have to do anything... except of course, have our product in stock and sell it... its that easy.
The Motherboard specs: GA-EP45-DS4
Revolution Energy Saving design with DES Advanced features
Supports 45nm Intel Core 2 Multi-core processors (1600MHz FSB)
Dual Channel DDR2 1333+ for remarkable system performance
2x PCI-Express2.0 16X graphics interface with CrossFireX support
Diagnostic LED and ACPI LED's on-board to display system and power status
2x Gigabit Ethernet LAN with Teaming functionality
Supports Dolby Home Theater audio for stunning surround sound
DualBIOS solution for multiple security to your system
Power/Reset/Clr CMOS onboard buttons for easy operation
Hardware Overvoltage Control IC
Blu-ray playback outputs supported by high-quality 106dB SNR ALC889A HD Audio
What are the Terms and Conditions ?
One pen drive per household
Valid from the 1st Oct to 31st Oct 2008
This promotion is only valid for UK mainland
For more details, please click on the below link...
forum.giga-byte.co.uk/index.php?board=2.0
Stats: 0.035 seconds
