Temperatures at a glance: Scythe Kama Thermo Wireless Simplifies Temperature Monitoring
Hamburg, October 1st 2008: The Japanese manufacturer Scythe Co., Ltd (Tokyo, Japan) announces its Scythe Kama Thermo Wireless. This infrared-thermometer the dimensions of 29.5 x 80.0 x 16 mm (WxHxD) and has a weight of 35 gram – nevertheless it is highly functional. Everybody who wants to control the temperatures at a PC-system can do so from now on – everywhere and without annoying and fragile temperature probes.
The Scythe Kama Thermo Wireless uses infrared rays to measure temperatures without having direct contact to the object. Just aim, press the button and read out the temperature! Because of its small measurements, the thermometer can be used everywhere – at home, at a LAN-party or in the office.
Because of its two power-sources – on the one hand, there is a button battery included and on the other hand, USB can be used – and because of the ability to use Celsius as well as Fahrenheit, the Kama Thermo Wireless is highly versatile.
The Scythe Kama Thermo wireless is available for a MSRP of 8,90 Euro in Europe.
www.scythe-eu.com/en/products/pc-accessory/kama-thermo-wireless.html
Specifications
Model Name:
Model #:
SCKTW - 1000WH (White)
SCKTW - 1000BK (Black)
Manufacturer:
Scythe Co., Ltd. Japan
Dimension:
29.5 x 80.0 x 16 mm (W x H x D)
Temperature Unit:
Celsius / Fahrenheit
Temperature Range:
0 ~ 100°C / 32 ~ 212°F
Usage Ambient Temperature:
-10°C ~ 50°C / 14 ~ 122°F
Response Time:
1 Second
Measurement Accuracy:
+/- 2 °C
Measurement of Vision Range:
10 / 100 mm (D:S=1:1)
Emittance:
0.95
Power:
Button Lithium Battery CR2302 x 1 or USB
Storage Temperature:
-20 °C ~ +65 °C
Weight:
35 g (incl. Battery)
