Apple has announced its new range of MacBooks and its first LED backlit Cinema Display at a press conference at its Cupertino headquarters.
The company presented new 13.3" MacBook and 15.4" MacBook Pro designs – the chassis are, like the rumours suggested, built from a solid block of aluminium.
There were two new MacBook Pro models announced, both featuring a 15.4" LED-backlit display with a glossy covering that will undoubtedly split opinion down the middle. What's more there's no matte option available with any of the new MacBooks – it's clearly going to be a love-it-or-hate-it affair.
The priciest model comes in at £1,749 (inc. VAT) and features a 2.53GHz Core 2 Duo (6MB L2 cache), 4GB of DDR3 1,066MHz memory, a 320GB hard drive, a GeForce 9400M integrated graphics chipset and a GeForce 9600M GT 512MB discrete graphics card.
The cheaper MacBook Pro comes in at £1,399 (inc. VAT) and features a 2.4GHz Core 2 Duo (3MB L2 cache), 2GB of DDR3 1,066MHz memory, a 250GB hard drive, a GeForce 9400M IGP and a GeForce 9600M GT 256MB discrete graphics card.
Both weigh 2.5kg, feature a pair of USB 2.0 ports, a Firewire 800 port, a mini-DisplayPort socket, Gigabit Ethernet, integrated 802.11n WiFi, a built-in iSight camera and everything else you'd come to expect. There's one thing you won't be familiar with though, and that's the button-less multi-touch glass trackpad – there are no buttons and you tap the trackpad instead of clicking a trackpad button.
Apple intros new MacBooks, 24
The new 15.4" MacBook Pro
These are undoubtedly expensive notebooks though and definitely not for everyone – for those with thinner wallets, Apple has updated the MacBook range with a design that's very similar to the new 15.4" MacBook Pros.
The cheapest of the two MacBooks comes in at £949 (inc. VAT), which raises the entry-level bar for Apple's notebooks. The company has, however, kept the old White MacBook in its range at a reduced price of £719 in order to fill the void at the bottom of Apple's range.
The new entry level MacBook still uses a 13.3" LED-backlit display (complete with the same glass cover as the new MacBook Pros) and comes with a 2.0GHz Core 2 Duo, 2GB of DDR3 1,066MHz memory, a 160GB hard drive and a GeForce 9400M integrated graphics chipset. The more expensive MacBook comes with a 2.4GHz Core 2 Duo and a 250GB hard drive – the rest of the specs remain the same. The price increase for these upgrades is a cool £200 once you factor in the tax man's cut.
The new 13.3" MacBook
Like the new MacBook Pros, the MacBooks feature a pair of USB 2.0 ports, a mini DisplayPort socket along with Gigabit Ethernet and 802.11n wireless networking and a built-in iSight camera - bizarrely there's no Firewire port, though. The new models weigh almost a quarter of a kilo less than the older MacBook at just over 2kg and they're also thinner as well at 24mm.
There was also an updated MacBook Air announced, but nearly all of the flaws with the initial design remain. The only notable changes are the upgrade to Nvidia GeForce 9400M integrated graphics and the decision to swap out the mini-DVI connector for mini-Displayport. There are also bigger hard drives (using SATA instead of IDE this time) and Apple has moved the Air to DDR3 like the newer MacBooks, but that's about all that has changed.
Interestingly, despite Steve Jobs essentially announcing the death of Ethernet when he unveiled the MacBook Air, both the MacBook and MacBook Pro sport Gigabit Ethernet sockets. The other annoyance for me is the inclusion of a mini DisplayPort connector – there's simply no reason for it whatsoever, other than to coax people into buying either an adapter (mini DisplayPort to dual-link DVI costs in the region of £70, for what it's worth) or buying one of Apple's new 24" LED Cinema Displays.
Speaking of which, this was the surprise announcement during the keynote – but it was long-overdue. This has a characteristically sleek design, features LED backlighting, a glass (glossy) cover a 1,920 x 1,200 native resolution, built in stereo speakers, a USB 2.0 port, a mini DisplayPort connector and a MagSafe power connector for charging your MacBook. This won't come cheap at almost £650 (inc. VAT) but it does look pretty nice – the question is whether it actually performs as well as it looks.
On the whole, I'm a little disappointed with the announcements in some respects – my biggest disappointment is the increased barrier for entry. The other major disappointment for me is the inclusion of the mini DisplayPort connector – there's plenty of room for a full-sized DisplayPort socket, but that'd mean Apple can't fleece even more money out of those wanting to use a non-Apple display. Sure, it won't fit on the MacBook Air, but frankly anyone buying a notebook with such a flawed set of connectivity options afforded by the form over function design should be fleeced for as much as possible in my opinion.
With that said, there are some good trends – I like the fact Apple has included a decent GPU (even if it's integrated) in all of its notebooks, as it could signal Apple's intention to really harness the power of the GPU with its drive behind OpenCL. The designs look stunning as well, but I'm still concerned with their robustness when it comes to accidental spillages – I doubt the keyboard is splash proof, for example.
That's enough to prevent me from buying one, that's for sure, but I'm confident that many will love the new MacBooks – but there'll be an equal number who won't because there is no option for a matte display. Share your thoughts on the announcements with us in the forums.
Quote GreatOldOne 15th October 2008, 16:43
The entry level MacBook is still the white plastic one, as Apple will still be producing it, and selling it at a cheaper price point... If you're in the US. Apparently, a cheaper price point in the UK is an increase from £699 to £719. An increase of £20!
I want a new MBP, but can't really justify it. My 2006 model runs just fine and I've just upgraded the wifi, HDD and maxed out the memory.
Maybe next year. :)
Quote lamboman 15th October 2008, 16:51
Holy crap. £649 for a 24 inch display? Yeah, LED backlit, but apart from that. No DVI (we can't expect HDMI from Apple, to be fair).
The new MBs and MBPs are alright.
Quote pimlicosound 15th October 2008, 17:26
"Like the new MacBook Pros, the MacBooks feature a pair of USB 2.0 ports, a Firewire 800 port, a mini DisplayPort socket along with Gigabit Ethernet and 802.11n wireless networking and a built-in iSight camera."
The new Macbooks don't have Firewire ports.
Quote greensabbath 15th October 2008, 17:28
I was never impressed with the macbook air, primarily because it felt cheap due to the keyboard. I'm glad they've updated most of their line to look equally as cheap... makes the decision to stay with my Lenovo that much easier.
Quote p3n 15th October 2008, 17:35
getting me a MBP, probably won't use my PC outside of FPS games - unless I get a dvi adapter then the mbp is just as capable! m$ will be happy to hear I got an OEM vista for steam too, bye bye summer bonus!
Quote kempez 15th October 2008, 18:33
I was seriously debating buying a new Macbook, but the increased pricepoint is hugely disappointing and frankly the styling isn't up to what I think Apple's standards are. If I can buy a Sony or even a Dell that's better looking than an Apple, at a far far smaller price, then why bother?
The lack of Firewire is going to seriously miff some video buffs!
Quote lewchenko 15th October 2008, 18:41
This is the worst update from apple in a long time.
- the base price for the macbook pro is £1400 !!! I paid less than less oin Feb 2007 for the entry level macbook pro. Plus my model has DVI and FW400 so no adapter leads required.
- glossy screens only for the pro models - no thank you.
- macbook has no FW port anymore. Which means no more home video as the camcorder won't connect to it.
- base mac book price for the revised model is a whopping £949. Holy rip off Batman!
- New cinema display is useless to me without a set of pricey adapters, plus its way overpriced to say to dell wfp2008 24 inch screen.
Complete crap from apple - and this is coming from someone who normally loves their stuff.
Quote reflux 15th October 2008, 18:42
Lovely designs, but they're looking more and more like PCs now they've dropped the all-white.
Quote freedom810 15th October 2008, 19:15
Okay so macs look great but specs wise you seem to be far better going for a dell or other brand.
Quote naokaji 15th October 2008, 20:52
Desktop LCD with Led Backlight? about time...
I just hope that now the cherry is popped many others will follow and prices will dorp to acceptable levels.
Quote oasked 15th October 2008, 21:46
Bloody hell those are expensive for the specs you get.
Quote Volund 15th October 2008, 21:51
It is a product from apple corp... what do you expect?
This update makes me giggle :D:)
Quote Cupboard 15th October 2008, 22:24
I agree with also the "meh" and "wtf" comments above... but two graphics cards in a laptop :D
That is a good idea, let's hope you don't have to restart in order to swap.
Quote bubsterboo 15th October 2008, 22:48
Speaking of the keyboard. What if you get hair or crumbs down their? How are you suppose to clean it? Because it's their new "unibody" design, wouldn't you have to take apart the whole thing?
Like the old design better IMHO.
Quote sheninat0r 15th October 2008, 23:06
You have to log off and then on again to switch.
Quote Amon 15th October 2008, 23:24
I think you're paying mostly for materials, and not the assembled laptop.
Low value, indeed. But, it's still better value than buying an Aston Martin "for the specs you get".
Quote Volund 15th October 2008, 23:43
hum, but an Aston Martin at least looks cool in my driveway.... the mac out there is just a charred hulk :P
Quote eeevan 16th October 2008, 01:02
Everyone stop.
14ms response time.
yeah.
lol
Quote lamboman 16th October 2008, 19:30
Apple also need to give us FIGURES rather than just (1.x times faster) as well. Yeah, the 9600M GT might be 2.3x faster than the 9400 chip, but if it is only pushing 2.3FPS, then that isn't great... (obviously, a stupid example, but you get what I mean).
While I do like some of the new features, I do think that Apple are running out of ideas. Similarly priced PC laptops are better on power and features, and MS seems to be catching up with Mac OS X, if things go to plan...
Quote tominated 16th October 2008, 22:21
gonna buy the macbook as soon as i get teh monnies
Quote Platinum 25th November 2008, 10:21
Originally Posted by eeevan
Everyone stop.
14ms response time.
yeah.
lol
Your eyes cannot tell any difference below 16ms so whats the problem?
