The Japanese cooling specialist Scythe Co. Ltd. unveils the new CPU Cooler Stabilizer 775. With this product, mounting of LGA 775 Coolers is possible without using the Push Pins. With the supplied Push Pin Removal-Tool, displacing the original Push Pins is no problem anymore. Secure mounting of the cooler is possible using Back-Plate and screws. The whole product consists of metal and is really solid.
When using the Stabilizer on Socket 478 CPU Coolers, the included mounting bars are used. By using those, the CPU Cooler Stabilizer 775 provides a better contact pressure between CPU and Cooler than using conventional mounting solutions.
The CPU Cooler Stabilizer 775 is a consequent selective further development of the popular Universal Retention Kit. Included in the package, there are many accessories to ensure compatibility and performance: Back-Plate, Metal Mounting Bar for Socket 478, Screws, Copper Spacer, Insulation Washer, Push-Pin Removal Tool and a small package of Thermal Grease.
Scythe CPU Cooler Stabilizer 775 is available for 6,90 Euro + VAT / US$ 11,50 + TAX. For K8 / AM2 and AM2+, CPU Cooler Stabilizer AM2 will be announced within the next couple of weeks.
Model Name:
Model #:
SCCSI-775
Manufacturer:
Scythe Co., Ltd. Japan
Contents:
Back-Plate, Metal Mounting Bar for Socket 478, Screw for Back-Plate, Copper Spacer, Insulation Washer (Thick), Insulation Washer (Thin), Screw for Back-Plate (775), Fixing Screw for Back-Plate (775), Fixing Screw for CPU Cooler (775), Push-Pin Removal Tool, Thermal Grease
Compatibility:
Motherboards with LGA775 Socket
www.scythe-eu.com/en/products/pc-accessory/cpu-cooler-stabilizer-775.html
