The mission for SilverStone’s RAVEN team is to design products with styling and features that exceed classic originals in boldness and intention. So a brief look at the first RAVEN chassis, the RV01, one can easily see that the mission was accomplished with spectacular results. The RV01’s stealth fighter inspired outer shell is styled aggressively but with a small hint of SilverStone’s famed reservation by the use of only matte finish. This gives RV01 an unmistakable wow factor and a look that will remain pleasing for years to come. For the interior, a revolutionary layout was utilized to take advantage of a very simple natural phenomenon – heat rise, by rotating the motherboard 90 degree for air to rise up more smoothly over graphics card area. Equipped with dual 180mm fans and a 120mm fan, the RV01’s has excellent cooling potential with its factory tuning perfectly balanced between performance and quietness. If there is a breakthrough chassis to be had for several generations of components upgrade, the RAVEN RV01 is definitely the one.
Special Features
Extreme enthusiasts chassis
Revolutionary 90 degrees motherboard mounting
Natural airflow layout with positive pressure design
Dual 180mm silent fans included
RAD-support included for optional liquid cooling
Flexible drive storage options with hot-swappable SATA adapter
SilverStone Big-Tower Raven RV01 with stack effect cooling!
