MSI has claimed that setting up Intel's new Optane accelerators involves 'several challenging steps' but that it has an answer: the one-click MSI Optane Genie.
Announced
back in 2015 with a since-missed 2016 launch window, Optane is Intel's name for the 3D Xpoint solid-state memory technology it co-developed in partnership with Micron. Its initial outing was aimed firmly at the data centre and high-performance computing markets, taking the form of
a PCI Express add-in card which can add 375GB of high-performance non-volatile memory to a system for use as either high-speed cache or system RAM. Its consumer version, however, is somewhat more limited:
an M.2 module which adds 16GB or 32GB of storage cache to
selected Kaby Lake systems, with claims it can boost performance even when paired with traditional SATA-bus SSD storage.
MSI, though, has a warning: using Optane isn't as simple as just plugging the board in and off you go. '
Normally users would have to go through several challenging steps to successfully configure and enable Optane memory boosting,' the company has opined in a press release for its solution to this alleged problem: MSI Optane Genie. '
Optane Genie is an easy and smart installation tool found in the latest BIOS, which enables the use of Optane memory with just 1-click,' the company's announcement continued.
Optane Genie isn't an application, however, but rather a feature of the company's latest BIOS revision for selected 200 Series motherboards. Accessed from the UEFI, Optane Genie activates in a single click followed by what the company rather vaguely refers to as '
following the instructions to finish the easy setup.' As a slight sticking point, though, anyone wanting this allegedly beginner-friendly method of activating Optane will need to download an updated firmware file and flash it, something many users still consider a scary prospect.
Those with an Optane-compatible MSI 200 Series motherboard are advised to check the company's website for updated firmware, though MSI has stated that Optane will work perfectly on earlier firmware revisions - simply without the Optane Genie one-click activation feature.
