December 7, 2018 | 15:35
Companies: #adata #amd #asus #bit-tech #scan-computers #thermaltake
        Sam's gone to town with the bright and shiny with his Neon mod. The front panel sports a large RGB infinity mirror that lends a curious depth to the build. Inside, Sam constructed a huge custom reservoir that also serves as a waterfall and sports the Thermaltake logo on the side. Neon vinyl wrap and reflective paint throughout the components and case add visual flair and tie things to the project theme.
To support his internal modifications, Sam made a new base for the chassis that raises it off the ground, not only providing room for cooling but also allowing the lighting to bounce off the ground for an underglow effect. Lighting has been used liberally all around to accent the acrylic panels and films, including the etching work on the rear panel, reservoir, and motherboard tray.
Has Sam taken his build to infinity and beyond? Let your vote do the talking!
