HDD Activity Meter
Written by Dave Williams
June 23, 2002 | 00:00
Tags: #circuit #hard-drive #led #pcb #solder
Companies: #mod
20 LED versions
In this design the effect is of a pair of LEDs moving away from each other, (DOT mode), or, if using BAR mode, a row of LEDs expanding outwards away from each other.
HDD Activity Meter 20 LED Versions
Parts List with order codes for UK and US suppliers
20 individual LED version
As in all the board designs for the HDD meter, R3 is fitted in its alternate position and VR1 is replaced with a wire link. There is a total of three links on this board.
Component layout - top view.
Track layout - Viewed from above.
The finished board.
The PCB layout if using two 10 LED arrays
Again three links are used here.
HDD Activity Meter 20 LED Versions HDD Activity Meter 20 LED Versions
Component layout - top view (left) and Track layout - Viewed from above (right)
The finished board.
Wiring detail between the LED arrays viewed from above.
Project Onda v2 - Part III
September 23 2021 | 09:05
