Right side
While often most of the attention goes to the left panel, the right side panel is the poor, distant relation which is often neglected. Many people won't see this side of the case, but it's good to give them a nice surprise when they look around this side.
It is a large, blank canvas so I decided to use the head-to-head image I found. I printed it out and taped it securely to the side panel (removed from the case, of course). Here you can see that I have already started my outlining a little.
With the stencil removed, here is the outlined work-in-progress. It looks a little bit square, but that will change.
The few remaining details needed to be finished freehand, but I'm really pleased with the end result.
