Project Culance
Written by Dave Williams
August 10, 2003 | 07:44
Tags: #case #dave #macroman #project
Companies: #koolance
Now I needed a template for the next bit. The discarded door should provide suitable material...
Project Culance C U later
Project Culance C U later Project Culance C U later
And it did! The piece of off-cut was cut to shape and marked out ready for drilling. This piece of plastic will serve two purposes. The first is as a template...
The template was used to mark the holes for more tubes on the base section of the front panel.
And drilled using the same method as for the previous tubes. A quick test fit ensued.
Looking good. You may have noticed.....the template now doubles as a top retainer for the tubes. Two for the price of one. Cost cutting at its best!
Now it's starting to take shape.
