The tubes were polished to a brilliant shine and then covered with a sealer to prevent them from tarnishing. The sealant was left to harden overnight. The brushed steel panels were also given several coats of clear sealant.
Now I show you the front panel and bits sprayed with vinyl dye.
Another test fit to gauge the overall looks. Behind the bottom tubing will be a tinted window.
Once again a dilemma...
Should I use black tint like this? Or silver like this? Ooh, decisions, decisions... Ahh bugger it! Black it is!
