Corsair Carbide Series Spec-01 Review
Manufacturer: Corsair
UK price (as reviewed): £37.99 (inc VAT)
US price (as reviewed): $54.99 (ex Tax)
Budget enclosures are rarely the most exciting, but they're a necessary and crucial part of the market due to the sheer volume of cases sold at lower price points, especially in developing economies around the world. Thankfully, such products have come a long way in recent years, so even if you're not paying top dollar you don't need to settle for sacrificing basic features and build quality.
Corsair, one of the most well known chassis manufacturers, is now setting its sights on the high volume budget market with three cases launching today under the Carbide Series Spec brand. The Spec-01, which we're looking at here, is the cheapest of the bunch at just £38, and also Corsair's cheapest enclosure to date. Its previous budget Carbide case, the
200R, had lots of features and build quality but was lacking in the cooling department, so hopefully the Spec-01 will improve on this.
Externally, the Spec-01 is no dull black box, but as ever its styling won't be to everyone's taste. The thick vertical grilles at the front guard the case's red LED 120mm intake fan. Meanwhile, both side panels are extruded, with the left one also housing a large square window.
Build quality is very respectable on the outside. The front panel may be plastic, but it's thick and rigid and doesn't bend or creak, and though the case is fairly light its steel panels have only a little flex when pressure is applied. Our one small gripe is that the plastic feet have no rubber soles, so there's little grip on smooth surfaces.
Below the front 120mm fan is a second 120mm mount. There are also two empty 120mm mounts on the roof and a further one at the rear, for a total of five. Even at £38, we were a little disappointed to find that the front intake is the case's only fan. We've seen similarly priced cases such as the NZXT Source 210 and Antec One ship with two fans. Also, even when limited to one fan we'd pick a rear or roof exhaust position over a front intake, as this is typically more effective at cooling. The empty mounts do mean that the CPU area is at least well ventilated, so there are openings through which heat can rise, but without fans to exhaust air faster overclocked systems may find the CPU and VRM areas rapidly getting hot when the system is under load.
One thing that's good to see in so cheap a case is dust filtering material, which is fitted to the rear of the front grilles. It's not independently removable but the front panel itself is easy to pop off for cleaning. There's also a slide out filter beneath the PSU, though like many such designs it can be difficult to replace properly without lifting the case up slightly. One overlooked area is the roof, where the empty fan mounts are unshielded from dust, though it's rare to see filters in this location at this end of the market.
The I/O panel includes a single USB 3 port with an internal header, alongside the usual audio jacks and a USB 2 port. It's a shame that both USB ports aren't USB 3 ones, but one is still better than none. There's no built in fan control, but the power and reset buttons are solid and satisfying to press. Beneath the I/O panel are the two 5.25-inch drive bay covers.
Specifications
- Dimensions (mm) 200 x 413 x 467 (W x D x H)
- Material Steel, plastic
- Available colours Black
- Front panel Power, reset, USB 3, USB 2, stereo, microphone
- Drive bays 2 x external 5.25in, 4 x internal 3.5in/2.5in
- Form factor(s) ATX, micro-ATX, mini-ITX
- Cooling 2 x 140/120mm front fan mounts (1 x 120mm fan included), 1 x 120mm rear fan mount 2 x 120mm roof fan mounts (fans not included)
- CPU cooler clearance 165mm
- Maximum graphics card length 420mm
- Extras Removable dust filters
