AMD Radeon R9 280 - Overclocking
Using MSI Afterburner, we were able to get the XFX R9 280 DD Edition from 933MHz to 1,080MHz, a 147MHz improvement overall, which is also a tasty 16 percent. Under load, the card was able to stay at 1,080MHz with full consistency.
As for the memory, we managed to push it from 1.25GHz (5GHz effective) all the way to 1.575GHz (6.3GHz effective), the maximum permitted by Afterburner, with no stability issues. This indicates that XFX is indeed using 6Gbps memory chips for this card, though mileage will still vary. Either way, this is a fantastic 26 percent overclock that takes the cards memory bandwidth from 240GB/sec to 302.4GB/sec.
Under load, the power consumption of our system rose from 305W to 322W using the overclocked settings, which isn't bad at all considering the rather large clock speed gains we've seen.
Nvidia GeForce GTX 780 3GB
AMD Radeon R9 290 4GB
XFX Radeon R9 280 DD Edition 3GB (OC)
AMD Radeon R9 280X 3GB
Nvidia GeForce GTX 770 2GB
Nvidia GeForce GTX 760 2GB
AMD Radeon R9 270X 2GB
Frames Per Second
Frames Per Second
Nvidia GeForce GTX 660 2GB
1000
1500
2000
2500
Score (higher is beter)
