*How to build a touchscreen all-in-one PC Going Ghetto *How to build a touchscreen all-in-one PC Going Ghetto
Cardboard + zip ties is only duct tape away from being true ghetto style modding
After bolting on the motherboard, it was a case of routing, and hiding the SATA and power cables, while fixing the slim SSD to the back. In this case it's an Intel X-25M G1.
Fixing the SSD in position
There's not a lot needed for the build - we dropped in some standard Crucial DDR3 memory and the SSD: that's it. We then installed Windows 7 Home Premium 64-bit on it which automatically detected the wireless, touchscreen and bluetooth hardware, although Nvidia's Ion software was still required via Windows update. We didn't use the driver CD once.
It even stands up by itself! and later some, uh, "testing". Ahem
We were going to mount it to the top of the monitor with duct tape, but we found it left residue marks, so we revisited the zip-tie option again and mounted it to the back of the monitor stand, and zip-tied the d-sub and USB cables to the back of the cardboard to keep things neat.
The final setup
