miniNUC by Pavel Rafalovich
Project Log: Here
A word from Pavel :
MiniNUC is a case designed to show how compact a motherboard the NUC from Intel is. It is made in the style of HI-FI equipment. It can be used as a multimedia center or PC. To create the case I used oak planks and aluminum. The oak planks used for the outer shell and covered in acrylic lacquer.
I used aluminum for making the front and rear panels and then I put on the front panel labels using a laser printer and iron. The internal chassis I made using aluminum profiles. To cut the components I used an electric fret saw, router, sander, as well as various hand tools. I aimed to create an easy case to use and one that was compact and hopefully you'll agree I managed this with the end result.
Intel NUC Case Design Competition 2014: The Finished Projects miniNUC by Pavel Rafalovich
Click here to see the next project or head to the forum to vote.
