Manufacturer: Asus
UK Price: £129.99
US Price: $129.99
The full review is contained in the video, above, so I urge you to take a look at that. This companion piece offers my brief thoughts in written format.
For today's review, I have the Asus TUF Gaming K7 Keyboard. It is a full-sized keyboard that has taken on a frameless form, making it look more clean and compact. The main feature is the use of optical-mech switches. Instead of pieces of metal to actuate, they use an infrared light beam for better accuracy and quicker response times.
It also provides per-key RGB LED lighting customisation through ROG Armory II software and the ability to use the onboard FN key lighting modes and the much-needed media controls.
Specifcations:
Box Contents:
After using the Asus TUF K7 Keyboard, here are my thoughts.
It is a very robust, premium-quality keyboard, thanks to the solid aluminium frame. It definitely looks the part in any setup, whether it's at the work office or at home for gaming. The RGB backlighting can be fully customised either via the easy-to-use Asus Armory II software. The RGB LEDs looks a little dim against the frame. That's not a criticism because the effect is subtle rather than glaring, as on some of the competition.
It includes a fantastic ergonomic memory foam detachable, magnetic wristrest. It can easily be pushed against the keyboard to attach itself or pulled away to detach if you're finished with it.
I normally use the Cherry MX Speed Silver Switches on my daily driver, so I was really interested to try out the Optical-Mech Tactile Switches as they were a completely new experience. My first thought, and one that exists to this day, is how loud they are, producing an obvious clicky-clacky sound that is hard to get used to if you're coming a quieter keyboard - see the video to appreciate what I mean here. The performance of the switches, however, was solid. They're very accurate and responsive, which is a welcome surprise to me.
Overall, then, a very comfortable keyboard that's let down by ultra-loud switches.
The Good:
The Not So Good:
