Cebit 2005 Part 1
Written by Dave Williams
March 28, 2005 | 01:00
Tags: #ahanix #case #dave-williams #hoojum #small-form-factor #yeong-yang
Companies: #cebit #coolermaster #silverstone
Cebit 2005 Part 1 Still on the case...
Coolermaster did have a few cases on display.
Including the now de rigor media centre style case.
Cebit 2005 Part 1 Still on the case... Cebit 2005 Part 1 Still on the case...
Outwardly the cases look nice but uninspired.
CoolerMaster were quite excited to show us their Stacker RC-830 case. Described as the "most powerful use ever". I'm not sure what it means but I sure made me smile. It can apparently take just about every "X" type mainboard in existence. E-ATX, ATX, M-ATX, BTX, M-BTX and PICO-ATX. It certainly has the X-factor!
It's an all(ish) aluminium construction with a 120mm intake fan and 2 x 120 exhaust fans with plenty of provision for more.
This brick is a 4-in-3 device module. It can hold 3 x 3.5" drives and contains a 120 mm cooling fan which runs a 1200rpm to keep things both cool and quiet. If can fit in the RC-830 case.
Here is the RC-830 with it's ventilated side panel in place. You can also see mrhaz explaining his theory of sandwich making to a bemused onlooker.
Time for some small stuff...
