CoolerMaster were not exactly sitting on their laurels either.
CeBIT 2004 Part 3 Coolermaster Cases / H2O cooling
Very beautiful and shiny Wavemaster cases
The new Stacker range. Like the new Lian-Lis they have a fully perforated frontage to aid cooling.
Designed for HTPC use is the Cavalier range of cases.
CeBIT 2004 Part 3 Coolermaster Cases / H2O cooling CeBIT 2004 Part 3 Coolermaster Cases / H2O cooling
Also available in a vertical form factor.
Also from CoolerMaster comes the \"Aquagate\" an all in one liquid cooling system. Straight out of the box it can be used in one of three configurations. Here it is installed as a single unit taking up two drive bays.
Here it is being used externally from the PC case. Note this is a completely self contained unit requiring no other parts.
Here in its third configuration is the control panel mounted in a single drive bay...
With the main unit mounted inside the case. Currently the Aquagate will only cool the CPU but CoolerMaster expect to add GFX, chip set etc. cooling soon.
In Part 4 we shall be looking at cooling stuffs and small form factor cases amongst other things...
