Next, we head on to the two tests run using the new NF-A12x25 LS-PWM as well as the NH-P1. Although designed primarily for passive cooling, the heatsink does come with holes and mounting hardware so we've put the shiny, new fan to good use. As far as fan speeds go, we left the default motherboard fan profile and even at 100% load the fan was as close to silent as you can get.
First in the temperature graph we can see that after the dip around 170 seconds in the temperature then flat-lines around 41°C. Looking at the frequency graph and output CSV, we can also see a slight clock-speed increase of about 50MHz. Not much but measurable and at a lower temperate for essentially no trade-off. Adding a slight clock-speed bump to get to a locked 4GHz again proves no worry for the cooler with us hitting a steady delta of around 44°C above ambient. This is once again a great temperature and proves we could probably push it further with some more tuning.
Combining the excellent out-of-the-box cooling, the historic great service and the reviewers' dream of a mounting system it's hard not to give the Noctua NH-P1 a recommended award here. That award does come with the caveat of being for the processors the cooler is designed for, but if you're in the market for a top-of-the range passive or silent cooler, then for not just £100, but pretty much anywhere, I can't see where you could do better.
