With Radeon WattMan, we set the card to its highest power limit (150 percent), but sadly any adjustment we made to the peak clock speed setting of the voltage-frequency curve resulted in instability. That said, the higher power limit alone is enough to allow for higher boosting and is technically an overclock.
The memory was stable at a speed of 935MHz, which is the equivalent of 14.96Gbps, an increase of around seven percent.
