We introduced some OpenCL/OpenGL benchmarks to our test suite to coincide with the Kaveri launch, as they are important and steadily growing open source frameworks that are especially relevant to APUs due to the focus on GPU acceleration. Please note that we've only had a chance to test the most relevant processors in these new tests. Also, these are not OpenCL 2.0 benchmarks, and as such none of them are optimised to take advantage of AMD's HSA features.
MuseMage 1.9.6
Website: www.musemage.com
MuseMage is a GPU accelerated image editing software with plenty of advanced features and batch processing. It has a built in benchmark that applies a series of effects and filters to an image in quick succession, awarding a linear score based on completion time.
        AMD A8-7600 (3.3GHz)
        AMD A8-7600 (3.1GHz)
        AMD A8-6500T (2.1GHz)
        AMD Athlon 5350 (2.05GHz)
        Intel Core i3-4330 (3.5GHz)
          2000
          3000
          4000
          5000
    Points (higher is better)
Rightware BasemarkCL 1.1
Website: www.rightware.com
BasemarkCL is a comprehensive OpenCL and OpenGL benchmarking suite from Rightware that runs a series of heavy parallel workloads, from image manipulation techniques like smoothing and noise reduction, to fluid and wave simulations as well as ray tracing and fractal rendering. We run the entire suite on the GPU portion of a chip and report the final overall score.
        AMD A8-7600 (3.1GHz) (45W TDP)
            57.612
            44.017
            37.106
            21.940
