Power Consumption
For all of the performance tests, we disable all power-saving technology in order to give us a consistent set of results, and also best-case performance numbers - even though technologies such as Intel's SpeedStep might only take microseconds to kick in, that can make a difference in some tests.
However, for the power consumption tests we re-enable everything in order to get a real-world power draw. The power draw is measured via a power meter at the wall, so the numbers below are of
total system power draw from the mains, not the power consumption of a CPU itself. Measuring the power draw of any individual component in a PC is tricky to impossible to acheive.
Idle Power Consumption
For this test, we leave the PC doing nothing but displaying the Windows 7 desktop (with Aero enabled) for a few minutes and record the wattage drawn from the wall via a power meter.
AMD FX-8350 (4GHz/4.8GHz)
Intel Core i5-3570K (3.4GHz/5GHz)
Intel Core i7-3770K (3.5GHz/4.8GHz)
AMD FX-8120 (3.1GHz/4.65GHz)
AMD FX-8150 (3.6GHz/4.818GHz)
Intel Core i5-2500K (3.3GHz/5GHz)
AMD Phenom II X6 1100T Black Edition (3.3GHz/4.2GHz)
Intel Core i7-2600K (3.4GHz/5GHz)
Intel Core i7-3930K (3.2GHz/4.7GHz)
Intel Core i7-990X Extreme Edition (3.46GHz/4.6GHz)
Intel Core i7-920 (2.66GHz/4.04GHz)
Intel Core i7-3960X Extreme Edition (3.3GHz/4.7GHz)
Watts, lower is better
Load Power Consumption
For this test, we want to only stress the CPU, so use the smallfft stress test of Prime95 to fully load all available processors (logical as well as physical). We leave Aero enabled, and wait a few minutes for any power saving technology to kick in and for the power consumption to level out before taking our reading.
200
300
400
500
600
Note: the AMD chips were tested in an ATX motherboard, while the Intel LGA1155 chips were tested in a micro-ATX board. This difference can account for up to 20W, as we found in our Energy Efficient Hardware feature.
Posted by xxxsonic1971 - Tue Nov 06 2012 11:21
Posted by GuilleAcoustic - Tue Nov 06 2012 11:26
But I'm more tempted by an A10-5700 (space issue and low power requirement).
Posted by rollo - Tue Nov 06 2012 11:39
For the gaming platform i run i still dont have a reason to upgrade my overclocked i7950 to something faster. my vid and photo edit machine was upgraded already.
Posted by GuilleAcoustic - Tue Nov 06 2012 11:43
