AMD Opteron 2435 CPU Review
Written by James Gorbold
July 7, 2009 | 09:58
Tags: #dual-processor #energy-efficiency #hpc #istanbul #opteron #power-efficiency #server #six-core #socket-f #workstation #xeon
Companies: #amd
Crysis
Website: Crysis
Crysis is seen by many as the poster boy for DirectX 10 and it will make your system quite literally fall over crying if it's not up to – it’s a monster of an engine! It doesn’t come as much of a surprise then, that the graphics are something special – they’re above and beyond anything we’ve ever seen in a PC game even still.
We used the 1.2 patch and range the game in 64-bit and DirectX 9 mode in a custom level run through.
Crysis (minimum frame rate)
1,280x1,024 2xAA, All High Settings
  • 2 x Intel Xeon W5580 (Two 4x3.2GHz, 6.4GT/s QPI, 3xECC DDR3-1333)
  • 2 x Intel Xeon X5482 (Two 4x3.2GHz, 1.6GHz FSB, 2xFBD DDR2-667)
  • 2 x AMD Opteron 2435 (Two 6x2.6GHz, 2.0GT/s HTT, 2xECC DDR2-800)
  • 2 x AMD Opteron 2382 (4x2.6GHz, 1.0GHz HTT, 2xECC DDR2-800MHz)
  • 36
  • 26
  • 23
  • 21
20
30
40
Frames Per Second - higher is better
Crysis (average frame rate)
  • 47
  • 34
  • 30
  • 28
20
30
40
50
X3: Terran Conflict
Website: X3: Terran Conflict
The space simulator X3: Terran Conflict makes a good benchmark for any high-end CPU, as its complex economic model and mammoth playing environment give the processor lots to think about.
X3: Terran Conflict (minimum frame rate)
1,280x1,024 2xAA 2xAF, All High Settings
  • 44
  • 38
  • 30
  • 28
20
30
40
X3: Terran Conflict (average frame rate)
  • 91
  • 69
  • 65
  • 63
50
75
100
Disappointingly, the six-core Opteron 2435s were underwhelming in our two game benchmarks, Crysis and X3: Terran Conflict. The Opteron 2435s were slightly faster than the Opteron 2382s in Crysis, with a minimum and average frame rate of 23fps/30fps respectively, compared to 21fps/28fps for the Opteron 2382s. However, X3: Terran Conflict ran slightly faster on the Opteron 2382s. Clearly, however, if you want to run games on your dual-processor workstation then a pair of Xeon W5580s is a far superior choice, as they ran Crysis with a minimum and average frame rate of 36fps and 47fps respectively, and were also significantly faster than the either Opteron system in X3: Terran Conflict.
