Power Consumption (Idle and Gaming)
Putting a realistic, repeatable load on a GPU to get a decent idea of its real world power consumption and thermal output has long been something with which we've experimented at
bit-tech. We've found that synthetic benchmarks such as FurMark thrash the GPU constantly, which simply isn't reflective of how a GPU will be used when gaming.
It's such a hardcore test that any GPU under test is almost guaranteed to hit its thermal limit, the mark at which the card's firmware will kick in, speeding up the fan to keep the GPU within safe temperature limits. Conversely, simply leaving a game such as
Crysis running at a certain point also isn't reflective of real world use. There's no guarantee that the GPU is being pushed as hard as other titles might push it, and the load will vary from play-through to play-through.
Eventually then, we've decided to use 3DMark06's Canyon Flight test as a real world representative, repeatable graphics test. It's a ferociously demanding test, pushing graphics cards to their limit, but also containing peaks and troughs in performance that match real world game play.
As the test is so demanding and GPU limited, we've set 3DMark to run the test at 1,280 x 1,024 with 0xAA and 16xAF (enabled in the driver), constantly looping the test for thirty minutes and recording the maximum power consumption and GPU Delta T (the difference between the temperature of the GPU and the ambient temperature in our labs).
        AMD Radeon HD 6870 1GB
        AMD Radeon HD 5770 1GB
        Nvidia GeForce GTX 460 768MB
        AMD Radeon HD 6850 1GB
        AMD Radeon HD 5870 1GB
        AMD Radeon HD 5850 1GB
        Nvidia GeForce GTX 560 Ti 1GB
        Nvidia Geforce GTX 460 1GB
        AMD Radeon HD 6950 2GB
        AMD Radeon HD 6970 2GB
        AMD Radeon HD 6950 1GB
        Nvidia GeForce GTX 570 1.3GB
        Nvidia GeForce GTX 580 1.5GB
        Nvidia GeForce GTX 470 1.2GB
        AMD Radeon HD 5970 2GB
        Nvidia GeForce GTX 480 1.5GB
            128
            129
            130
            131
            136
            136
            135
            137
            138
            141
            147
            150
            150
            160
            163
            164
          50
          75
          100
          125
          150
          175
    Watts at socket, lower is better
            212
            229
            238
            245
            247
            256
            270
            270
            278
            285
            306
            330
            341
            347
            363
            376
Thermal Performance
            8
            10
            11
            14
            14
            15
            16
            18
            19
            19
            20
            20
            22
            23
            25
            26
    Delta T in °C
            38
            44
            46
            46
            46
            46
            46
            46
            50
            50
            54
            54
            55
            56
            72
            72
          20
          30
          40
          50
          60
          70
          80
    Delta T in °C
For explanation of what these numbers mean, head to the
Results Analysis page.
