Power Consumption (Idle and Gaming)
Putting a realistic, repeatable load on a GPU to get a decent idea of its real world power consumption and thermal output has long been something with which we've experimented here at
bit-tech. We've found that synthetic benchmarks such as FurMark thrash the GPU constantly, which simply isn't reflective of how a GPU will be used when gaming.
It's such a hardcore test that any GPU under scrutiny is almost guaranteed to hit its thermal limit; the mark at which the card's firmware will kick in, speeding up the fan to keep the GPU within safe temperature limits. Conversely, simply leaving a game such as Crysis running at a certain point also isn't reflective of real-world use. There's no guarantee that the GPU is being pushed as hard as other titles might push it, and the load will vary between play-throughs.
We used to use the Canyon Flight test of 3DMark 06, as this was a punishing and repeatable test. However, we've now adopted
Unigine's Heaven 2.5 benchmark, as its DirectX 11 features will stress all the parts of a modern GPU. We use the default settings and a resolution of 1,920 x 1,080. We also check that 4x AA and 4x AF are enabled and that tessellation is set to Standard. We then hit the Benchmark button and watch the power draw from the wall between the grass field scene and the second dragon scene - this is the toughest portion of the test for both Nvidia and AMD hardware.
We also have GPU-Z running in the background, and leave the Unigine benchmark running for ten minutes to record a peak GPU temperature. We present the temperature as a delta T (the difference between the temperature of the GPU and the ambient temperature in our labs).
AMD Radeon HD 7750 1GB
AMD Radeon HD 7770 1GB
AMD Radeon HD 7870 2GB
Nvidia GeForce GTX 560 1GB
Nvidia GeForce GTX 560 Ti 1GB (Third party cooler)
AMD Radeon HD 7950 3GB
AMD Radeon HD 7970 3GB
AMD Radeon HD 6870 1GB
AMD Radeon HD 6850 1GB
AMD Radeon HD 5770 1GB
Nvidia GeForce GTX 550 Ti 1GB
AMD Radeon HD 6950 2GB
AMD Radeon HD 6950 1GB
AMD Radeon HD 6970 2GB
Nvidia GeForce GTX 570 1280MB
Nvidia GeForce GTX 580 1.5GB
Nvidia GeForce GTX 560 Ti 448 (Third party cooler)
AMD Radeon HD 6990 4GB
Nvidia GeForce GTX 590 3GB
81
82
87
88
89
89
90
91
91
92
92
94
94
95
102
106
108
113
134
System Power consumption in Watts
Nvidia GeForce GTX 550 Ti 1GB (custom PCB)
121
142
160
175
188
193
193
210
210
215
227
245
246
253
253
284
293
414
427
Thermal Performance
AMD Radeon HD 7770 4GB
Nvidia GeForce GTX 550 Ti 1GB (Custom cooler)
AMD Radeon HD 7750 4GB
AMD Radeon HD 5770 4GB
6
10
10
10
10
10
11
11
12
13
14
15
16
17
17
18
18
22
22
Delta T in °C
Nvidia GeForce GTX 550 Ti 1GB (custom cooler)
31
32
40
40
42
44
47
50
52
53
53
54
54
56
57
58
63
64
65
Delta T in °C
Read our
performance analysis.
