AMD Radeon HD 7950 3GB With Boost review
Written by Antony Leather
August 16, 2012 | 08:25
Tags: #7950-boost #tahiti-pro
Companies: #amd
AMD Radeon HD 7950 3GB review
Manufacturer: AMD
UK Price (as reviewed): approx £300 (inc VAT) (Estimated)
US Price (as reviewed): N/A
We've known about AMD's plans for a super-boosting HD 7950 3GB for a while now. In short, it's looking to do the same with this popular mid-range card as it has with its flagship HD 7970 3GB. The latter was recently pushed down to second place in the AMD graphics card league table thanks to the arrival of the HD 7970 3GB GHz Edition, which currently retails for close to £400 with standard HD 7970 3GB's demanding less of a premium at anywhere between £300 and £350 depending on when and where you look.
The HD 7970 3GB GHz Edition is nothing more than a 75MHz core clock speed bump over and above that of the standard card, with boosting speeds varying depending on which third party manufacturer has gotten their mits on it to tweak the boost speed depending on the thermal headroom of their cooler.
The new kid on the block is simply called the Radeon HD 7950 3GB. For clarity's sake we'll be referring to the new model as the Radeon HD 7950 3GB With Boost - potential purchasers will need to make sure they're buying the right version by checking the clock speeds. Here, the card has received a 15 per cent increase in clock speeds, boosting up to 925MHz on the core, while third party manufacturers have tweaked things a little further; Sapphire for example, will be releasing a 950MHz boosting VapourX version of the HD 7950 3GB.
*AMD Radeon HD 7950 3GB With Boost review AMD Radeon HD 7950 3GB With Boost review
Click to enlarge Most reference Radeon HD 7950 3GB's should have no problems with their BIOS being flashed to the Boosting version.
The new HD 7950 3GB With Boost we've used actually arrived before the original HD 7950 3GB launch, for the simple reason it's physically identical to the HD 7950 3GB. All AMD has done is apply a few tweaks to the BIOS, sent this to us with a flashing tool and a double click later we'd turned our reference card into the 925MHz Boosting model. While AMD told us that it won't be officially offering the BIOS to current HD 7950 3GB owners due to the fact it might apparently cause issues with some third party cards, it's a fairly easy way to get a nice little speed bump.
As far as price goes, we've been given a rough price of £300, which puts it a little pricier than current HD 7950 3GB's which go for between £250 and £280. AMD, though, has told us the new SKUs arriving in the next few days should retail for the same price as current cards. However, as with the HD 7970 3GB GHz Edition, despite the fact the HD 7950 3GB With Boost will apparently go on sale from 16th August, we suspect supply could be extremely limited or non-existent. We hope to be proved wrong, but in any event, it will stand along side stock cards for the time being, so grabbing one and flashing the BIOS yourself.
 AMD Radeon HD 7970 3GB GHz EditionAMD Radeon HD 7970 3GBAMD Radeon HD 7950 3GB Special EditionAMD Radeon HD 7950 3GBAMD Radeon HD 7870 2GBAMD Radeon HD 7850 2GB
GPU
CodenameTahiti XT2Tahiti XTTahiti Pro2Tahiti ProPitcairn XTPitcairn Pro
Base Clock1,000MHz925Mhz875MHz800Mhz1,000MHz860MHz
Boost Clock1,050MhzNA925MHzNANANA
Stream Processors2,0482,0481,7921,7921,2801,024
Layout32 CUs, 128 SIMD Engines32 CUs, 128 SIMD Engines28 CUs, 112 SIMD Engines28 CUs, 112 SIMD Engines20 CUs, 80 SIMD Engines16 CUs, 64 SIMD Engines
Rasterisers222222
Tesselation Units222222
Texture Units1281281121128064
ROPs323232323232
Transistors4.31 Billion4.31 Billion4.31 Billion4.31 Billion2.8 Billion2.8 Billion
Die Size352mm²352mm²352mm²352mm²212mm²212mm²
Process28nm28nm28nm28nm28nm28nm
Memory
Amount3GB GDDR53GB GDDR53GB GDDR53GB GDDR52GB GDDR52GB GDDR5
Frequency1.5GHz (6GHz effective)1,375GHz (5.5GHz effective)1.25 GHz (5GHz effective)1.25GHz (5GHz effective)1.2GHz (4.8GHz effective)1.2GHz (4.8GHz effective)
Interface384-bit384-bit384-bit384-bit256-bit256-bit
Bandwidth288 GB/sec264 GB/sec240 GB/sec240 GB/sec153.6 GB/sec153.6 GB/sec
Card Specifications
Power Connectors1 x 6-pin, 1 x 8-pin PCI-E1 x 6-pin, 1 x 8-pin PCI-E2 x 6-pin PCI-E2 x 6-pin PCI-E2 x 6-pin PCI-E1 x 6-pin PCI-E
Stock Card Length275mm275mm265mm265mm246mm
TDP230W230W180W180W175W130W
Typical Street Price£350£350£270£270£230£185
Asus ROG Chariot RGB Gaming Chair Review
July 30 2021 | 08:54
