HandBrake Video Transcode
We've added HandBrake to our list of media creation tests, as PCMark 8's video encoding test isn't able to make use of more than two threads and as such doesn't give a true representation of video encoding/editing workloads and performance. As this task is a key reason for opting for a powerful system, we've added a simple encoding test using the freely available HandBrake software, which converts a 60-second, 400MB, 4K, MKV video sample to a high quality 1080p MP4 file using the available presets. Our results show much better scaling with increasing threads, which is more indicative of high-performance video editing suites, albeit without any GPU acceleration.
HandBrake Video Transcoding
4K MKV to high quality 1080p MP4 encode
  • Intel Core i7-6900K (4.2GHz)
  • AMD Ryzen 7 1700 (4.05GHz)
  • AMD Ryzen 7 1800X (4GHz)
  • AMD Ryzen 7 1700X (3.95GHz)
  • AMD Ryzen 7 1800X
  • AMD Ryzen 7 1700X
  • Intel Core i7-6850K (4.2GHz)
  • AMD Ryzen 5 1600X (3.95GHz)
  • AMD Ryzen 7 1700
  • AMD Ryzen 5 1600X
  • Intel Core i7-7700K (5GHz)
  • Intel Core i3-7350K (5GHz)
    • 74
    • 75
    • 76
    • 79
    • 83
    • 84
    • 89
    • 95
    • 97
    • 101
    • 103
    • 104
    • 107
    • 153
    • 204
    • 241
100
150
200
250
Seconds (lower is better)
  • Time
PCMark 8 Photo Editing V2
This workload involves making a series of adjustments to a set of photographs using ImageMagik - an open-source image processing library - to adjust brightness, contrast, saturation and gamma. When a favourable balance is found, the changes are then applied to the rest of the images in the set. TIFF files up to 67MB in size are used.
Load image matrix + adjusting times
  • Intel Core i7-6850K (4.4GHz)
  • Intel Core i5-7600K (5.1GHz)
  • AMD Ryzen 7 1700
  • AMD Ryzen 5 1600X
  • AMD Ryzen 7 1700X
  • AMD Ryzen 7 1800X
    • 23
    • 23
    • 24
    • 25
    • 25
    • 25
    • 29
    • 31
    • 31
    • 32
    • 32
    • 33
    • 33
    • 33
    • 34
    • 34
    • 34
    • 34
10
15
20
25
30
35
  • Time
CPU-Z
Publisher Cpuid.com
The popular tool for identifying key system information such as realtime CPU frequency, voltage, BIOS version memory speed, and a whole load of other figures, also includes a built-in benchmark tool. This assesses both single and multi-threaded performance in an extremely quick test directly within the usual interface. It also offers a stress test and the ability to limit the number of threads being benchmarked. We use the default settings and obtain both single and multi-threaded results.
CPU-Z Benchmark
Multi-threaded test
  • AMD Ryzen 7 1800X (4.0GHz)
  • AMD Ryzen 7 1800X
  • AMD Ryzen 7 1700X
  • AMD Ryzen 7 1700
  • AMD Ryzen 5 1600X
    • 20858
    • 20360
    • 20295
    • 18692
    • 18610
    • 18521
    • 17554
    • 15184
    • 15184
    • 14540
    • 11887
    • 11439
    • 10046
    • 9257
    • 5577
    • 4780
10000
15000
20000
Score (higher is better)
  • Multi-threaded
CPU-Z Benchmark
Single-threaded test
  • AMD Ryzen 7 1800X
  • AMD Ryzen 5 1600X
  • AMD Ryzen 7 1700X
  • AMD Ryzen 7 1700
    • 2504
    • 2432
    • 2368
    • 2342
    • 2332
    • 2299
    • 2249
    • 2162
    • 2130
    • 2069
    • 2049
    • 2038
    • 2038
    • 1840
    • 1794
    • 1794
1000
1500
2000
2500
  • Single-threaded
null
