Multi-tasking with 7-Zip and mplayer
Websites: www.7-zip.org and
www.mplayerhq.hu
Multi-tasking is a phrase with which we're all familiar, as most of us are now used to running multiple applications at the same time. However, to run multiple applications well you need a powerful (ideally multi-core) CPU and plenty of RAM.
Our multi-tasking test performs a massive file backup (with encryption) using 7-Zip, while simultaneously playing back a HD movie file using mplayer, making it a demanding test for any PC.
Asus Maximus VI Impact (Z87) (3.5GHz/4.7GHz)
Asus Maximus VII Gene (3.5GHz/4.8GHz)
MSI Z97M Gaming (3.5GHz/4.8GHz)
MSI Z97 MPower (3.5GHz/4.8GHz)
Asus Maximus VII Formula (3.5GHz/4.8GHz)
Gigabyte GA-Z97X-SLI (3.5GHz/4.7GHz)
ASRock Fatal1ty Z97 Killer (3.5GHz/4.8GHz)
MSI Gaming 7 (3.5GHz/4.8GHz)
Asus Maximus VII Hero (3.5GHz/4.8GHz)
MSI Z97S SLI Plus (3.5GHz/4.8GHz)
Asus Maximus VII Ranger (3.5GHz/4.8GHz)
Score, higher is better
Overall Score
The overall score is an unweighted mean average of the scores of the three individual tests. A score of 1,000 means that the test system is as fast as our reference PC, which used a 2.66GHz Intel Core 2 Duo E6750 at stock speed, 2GB of Corsair 1,066MHz DDR2 memory, a 250GB Samsung SpinPoint P120S hard disk and an Asus P5K Deluxe WiFi-AP motherboard. The scoring is linear, so a system scoring 1,200 points is 20 per cent faster than our reference system. Equally, a system scoring 1,200 is 4 per cent faster than a system scoring 1,150.
1000
1500
2000
2500
3000
