ATI Radeon HD 6950 Review
Written by bit-tech Staff
December 16, 2010 | 07:57
Tags: #benchmark #catalyst #comparison #directx-11 #dx11 #fast #fps #gtx-560 #performance #red-team #should-i-buy #speed #value
Companies: #amd #ati #test
Radeon HD 6950 2GB Specifications
While the Barts GPU of the HD 6800-series was a bit same-old, same-old, the new Cayman GPU of the HD 6900 is a big change. For a start, there’s two entire Front-End Engines, so the Cayman GPU has two triangle setup units, two tessellators and can send twice as much work per clock to the stream processors as previous Radeon GPUs.
Those stream processors have been upgraded, so they’re all capable of the high-precision work that only a fifth of the stream processors of previous generations were able to calculate. They’re organised in groups of four, with 16 of these groups per SIMD Engine (or stream processors cluster).
While this means that the HD 6970 2GB has fewer stream processors than the HD 5870 1GB, they’re more capable. ATI says the new layout, called VLIW4, is 10 per cent faster per mm2.
However, the HD 6950 2GB has even fewer stream processors, with only 22 SIMD Engines rather than 24, meaning it has a total of 1,408 stream processors. The lesser number of SIMD Engines means there are fewer texture units in the HD 6950 2GB than the HD 6970 2GB as well. The HD 6950 2GB runs at 800MHz rather than 880MHz.
The ROPs have seen upgrades too, and both HD 6900-series cards will have 2GB of GDDR5 memory running at comparably high frequencies to give the large amount of memory bandwidth from the 256-bit memory interface. While the memory of HD 6970 2GB runs at an astounding 5.5GHz (effective), the HD 6950 2GB has 5GHz (effective) memory, meaning it has 160GB/sec of memory bandwidth rather than 176GB/sec.
 ATI Radeon HD 6970 2GBNvidia GeForce GTX 570 1.5GBATI Radeon HD 6950 2GBATI Radeon HD 5870 1GBATI Radeon HD 6870 1GBNvidia GeForce GTX 460 1GB
GPU
CodenameCayman XTGF110Cayman ProCypress XTBarts XTGF104
Frequency880MHz732MHz800MHz850MHz900MHz675MHz
Stream Processors1,536 (880MHz)480 (1,464MHz)1,408 (800MHz)1,600 (850MHz)1,120 (900MHz)336 (1,215MHz)
Layout24 SIMD Engines15 SMs, 4 GPCs22 SIMD Engines20 SIMD Engines14 SIMD Engines7 SMs, 2 GPCs
Rasterisers242222
Tesselation Units2152118
Texture Units966088805656
ROPs324032323232
Transistors3.6bn3bn2.6bn2.15bn1.7bn1.95bn
SizeUnknownUnknownUnknown334mm2255mm2Unknown
Process40nm40nm40nm40nm40nm40nm
Memory
Amount2GB GDDR51,280MB GDDR52GB GDDR51GB GDDR51GB GDDR51GB GDDR%
Frequency1.375GHz (5.5GHz effective)950MHz (3.8GHz effective)1.25GHz (5GHz effective)1,050MHz (4.2GHz effective)1,050MHz (4.2GHz effective)900MHz (3.6GHz effective)
Interface256-bit320-bit256-bit256-bit256-bit256-bit
Bandwidth176GB/sec152GB/sec160GB/sec134.4GB/sec134.4GB/sec115GB/sec
Card Specifications
Power Connectors1 x 6-pin, 1 x 8-pin2 x 6-pin PCI-E2 x 6-pin PCI-E2 x 6-pin PCI-E2 x 6-pin PCI-E2 x 6-pin PCI-E
Maximum Power Draw250W219W225W188W151W160W
Idle Power DrawUnknownUnknownUnknown27W19WUnknown
Recommended PSUUnknown550WUnknown500WUnknown450W
Typical Street Price£310£300£235£320£220£155
