Super-budget Intel motherboards
Written by Antony Leather
November 20, 2012 | 08:14
Tags: #htpc #mini-itx
Companies: #bit-tech
Testing Methods
We test with our own Media Benchmarks suite, which can be downloaded so that you can test your own system. It uses a combination of Gimp image editing, H.264 encoding with Handbrake and multi-tasking with 7-Zip file compression combined with HD video playback. Finally, for our game testing we benchmark the board running Crysis 2 and Shogun 2:Total War and record the minimum and average frame rates.
As neither board we've tested here can overclock a K-series CPU, all the results are at stock speeds. The Asrock H61M-VS has a 16x PCI-E slot, so we've also included results for Crysis 2 compared to other motherboards when using our Nvidia GeForce GTX 680 2GB test graphics card. However, the MSI H61I-E35 (B3) is unable to support a discrete graphics card so could only be tested using the on-board graphics where necessary.
*Super-budget Intel motherboards Test Setup
Test Setup:
Motherboards:
  • ASRock H61M-VS
  • MSI H61I-E35 (B3)
Common Components:
  • Intel Core i7-3770K
  • 4GB DDR3 1,600MHz C9
  • Nvidia GeForce GTX 680 2GB
  • PC Power and Cooling Silencer 750W PSU
  • 120GB Patriot Wildfire SSD
  • Windows 7 Home Premium 64-bit
