Super-budget Intel motherboards
Written by Antony Leather
November 20, 2012 | 08:14
Tags: #htpc #mini-itx
Companies: #bit-tech
Power Consumption
We used Unigine's Heaven 3.0 benchmark, as its DirectX 11 features will stress all the parts of a modern GPU. We use the default settings and then hit the Benchmark button and watched the power draw from the wall between the grass field scene and the second dragon scene - this is the toughest portion of the test for both Nvidia and AMD hardware. We also used Prime95 to stress the CPU so combined we were loading both the CPU and it's on-board graphics to the maximum, representing the maximum power consumption you'll likely see.
Power Consumption (Idle)
Peak system power draw from the wall, Windows 7 Desktop, with Aero enabled)
  • MSI H61I-E35 (B3)
  • ASRock H61M-VS
  • 45
  • 47
20
30
40
50
Watts, lower is better
Power Consumption (Load)
Unigine Heaven Benchmark (1,920 x 1,080 4x AA 4x AF) and Prime
  • MSI H61I-E35 (B3)
  • ASRock H61M-VS
  • ASRock H61M-VS (with GeForce GTX 680 2GB)
  • 107
  • 111
  • 248
100
150
200
250
