Gaming Performance:
AOpen XC Cube EU965 Gaming Performance
Running the same tests at a higher resolution with both anti-aliasing and anisotropic filtering enabled meant that performance was graphics card limited. As a result, performance was almost identical on both the AOpen XC Cube and the Gigabyte boards. Even with just a GeForce 7600 GT installed, the frame rates weren't too bad and you'll be able to establish very playable and good looking gameplay at 1280x1024.
