Cooling Performance
Our test kit includes an ATI Radeon HD 5870 2GB Eyefinity 6 graphics card and an Intel Core i7-870 CPU, which has been overclocked from 2.93GHz to 3.4GHz using a vcore of 1.305V and a CPU PLL of 1.9V. This is a modest overclock, but our test kit will spend most of its life under high load, so pushing it too far isn't in anybody's interests. More importantly, some poorer-performing cases push the CPU temperature to above 80°C, so even this overclock will prove to be too much for some cases.
The CPU is cooled by a Gelid Tranquillo CPU cooler with a Noctua NF-S12B ULN 120mm fan. The NF-S12B ULN is a low-airflow fan, so it will highlight cases with poor cooling for the CPU. We also locked the fan speed on the graphics card to 30 per cent to prevent the automatic speed control interfering with the results.
We record the temperature of the CPU using
RealTemp, noting the temperature of the hottest core, and used
GPU-Z to log the temperature of the graphics card. Having recorded the ambient temperature in front of the main air intake of each case, we're then able to calculate the delta T - the difference between the ambient temperature of our lab and the temperature of the hardware. To load the system, we use a combination of the Canyon Flight benchmark in 3DMark06 and the smallfft test in Prime 95.
- CPU:
  Intel Core i7-870 CPU overclocked to 3.4GHz
- Graphics card: ATI Radeon HD 5870 2GB Eyefinity 6
 - Motherboard: Biostar TPower I55
 - RAM: 2 x 2GB OCZ 1,866MHz DDR3
 - Hard drive:  160GB Seagate Barracuda 7200.9
 - Heatsink: Gelid Tranquillo with a Noctua NF-S12B ULN fan
 - Power supply: Seasonic M12D SS-850EM
        SilverStone FT02R-W (max speed)
        SilverStone FT02R-W (min speed)
        Antec One
        Fractal Design Core 3000 (max speed)
        Cooler Master HAF X
        NZXT Source 210 Elite
        NZXT Phantom 630 (max speed; no HDD cage)
        Cooler Master HAF XM
        NZXT Phantom 820 (max speed)
        Chieftec DX-02B (max speed)
        BitFenix Shinobi XL
        Xigmatek Elysium
        Chieftec DX-02B (min speed)
        In-Win GRone (max speed)
        Fractal Design Define XL R2 (max speed; no HDD cage)
        Corsair Carbide 500R (max speed)
        Fractal Design Core 3000 (min speed)
        Fractal Design Define R4 (max speed)
        Corsair Carbide 500R (min speed)
        Lian Li PC-A76
        NZXT Phantom 820 (min speed)
        NZXT Phantom 630 (min speed)
        Xigmatek Midgard II (max speed; no HDD cage)
        Chieftec DX-02B (top fans off)
        Antec GX700 (max speed)
        Thermaltake Chaser A31
        Aerocool X-Predator X1 (max speed)
        In-Win GRone (min speed)
        Sharkoon T28
        Corsair Carbide 200R
        Nanoxia Deep Silence 1 (max speed; ventilated)
        CM Storm Scout 2
        Aerocool X-Predator X1 (min speed)
        Xigmatek Midgard II (min speed)
        Fractal Design Define XL R2 (min speed)
        Fractal Design Define R4 (min speed)
        Antec GX700 (min speed)
        Nanoxia Deep Silence 1 (min speed)
    °C, lower is better
        Cooler Master HAF X
        Xigmatek Elysium
        Antec One
        Sharkoon T28
        Lian Li PC-A76
        BitFenix Shinobi XL
        CM Storm Scout 2
    °C, lower is better
Read our
performance analysis on the next page.
