Cooler Master MasterCase Pro 5 Review
August 18, 2015 | 13:06
Tags: #atx #freeform #mastercase #mid-tower #modular-chassis
Companies: #cooler-master
Cooling Performance
For cases capable of housing ATX or larger motherboards, we use our standard ATX case test kit. which includes:
We disable the motherboard's onboard CPU fan control and all CPU power management features. The CPU fan is fixed at 5V with an adaptor while the graphics card fan is locked at 70 percent speed using MSI Afterburner. The system is loaded using Prime95 25.11 and Unigine's Heaven 4.0 benchmark. We use CoreTemp and GPU-Z to monitor the temperatures, taking the maximum values after 15 minutes - enough time for the readings to plateau.
Case performance - CPU Delta T
Difference over ambient
  • Cooler Master MasterCase Pro 5 (no HDD cage)
  • Phanteks Enthoo EVOLV ATX
  • SilverStone Kublai KL05
    • 59
    • 60
    • 63
    • 64
20
30
40
50
60
70
°C, lower is better
  • CPU delta T
Case performance - GPU Delta T
    • 43
    • 43
    • 44
    • 48
20
30
40
50
°C, lower is better
  • GPU delta T
